Question about Dell Inspiron 2200 Notebook
Open cover to resolder power jack
How do I open the cover on a dell inspiron 2200. I need to resolder the power jack to the motherboard. Thanks Roger
  • Dell Master
  • 998 Answers
You will need to remove the system board to gain access to the power jack. Here’s the link for the Inspiron 2200 service manual: http://support.dell.com/support/edocs/systems/ins2200/en/SM/index.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 10, 2008
How do i boot my dell inspiron mini
The problem is most likely in the DC jack in the laptop, it works it self loose over time until there is no power or intermittent power. The only solution is to dismantle the laptop down to the motherboard level to replace the plug or resolder back in place.
May 18, 2012 | Dell Inspiron Mini 10 Notebook
Is there an easier way to replace a dc power jack than soldering it? On an Inspiron 2200.
no
i'm afriad not my friend -- i have desoldered and soldered many DC jacks for Acers, dells, HP, IBM
Dell are some what eassiest, for most notebooks..just make sure
here is a video to help you
http://www.youtube.com/watch?v=1q0ln61p4hY
please rate my service
Nov 10, 2010 | Dell (8N816) Motherboard
I got a laptop Dell Inspiron 2200...I turn the power on and all the four (4) green lights goes on then flashes a bit a wont turn on... ANY CAN HELP ME.... Thanks
If the the four lights on the computer come and then go off. Then these are the diagnostics lights telling that the motherboard has gone bad and needs a replacement
If they flash in some sequence . The the problem could be with one of the internal components.
For more information on the same you can visit www.support.dell.com
Thanks for using fixya
proton
Jul 28, 2010 | Dell Inspiron 2200 Notebook
Battery will not charge. The battery is new, verified on another laptop and it works fine (takes a charge). Unit works fine when connected directly to AC. The laptop is a Dell inspiron E1505. How do I...
This isn't easily done. Have you recently replaced your power adapter for any reason. I've found that some laptop batteries won't charge if the charger is just slightly different from the original one, even if it's another Dell power adapter. If you haven't replaced the power adapter recently then it may be that your female power jack isn't properly seated or soldered into the motherboard. To reseat or resolder the jack with require you do completely dismantle your laptop. If you're not confident it doing this, then don't try it yourself. Also, resoldering the jack isn't as easy as it would seem either. Before doing any dismantling, remover your battery, turn on your computer and gently wriggle the adapter around in the female jack of the computer. Does your computer shut off on you? If so, then you definitely have power jack issues. See madhattercomputers.com
Mar 13, 2010 | Dell Inspiron E1505 Notebook
Repairing power connector inspiron 2200
The connector is special to Dell, and not generally available. You may need to purchase a new power supply. The connector has 3 concentric terminals, and one is used to 'ID' the power supply as genuine DELL. A plain DC connector can be used, but the batterys will not charge.
Mar 10, 2010 | Dell (8N816) Motherboard
AC adapter for dell laptop inspiron 2200
You can order the part from this link
Dell_PARTS_ADAPTER
Once you open the link scroll down and select the second adaper in the list
60 Watt 3 Prong AC Adapter with 3-ft Power Cord for Dell Inspiron 2200 / Latitude 110L Laptops
May 20, 2008 | Computers & Internet
DELL Inspiron 2200 Motherboard
Probably not. The circuit should be protected. just get a new AC cord
Mar 03, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 loose DC power pin connector
hi, the power jack must be removed by a strip out and de solder of jack and a new one fitted. I was lucky a guy took £30 for the job.
Feb 17, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 200 power jack
Yes if you are talking about the socket at the computer it requires old one to be desoldered and replacement part should be soldered firmly.
Good Luck
Feb 06, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
319 people viewed this question
Alun Cox
