Question about KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer
Kitchen aid mixer, voltage issue
As everyone know that we cannot use in Europe the kitchen aid mixer sold in the US because of the voltage. In the US, it's 110 volts-60 Hz, in Europe it's 220 volts 50/60 Hz. The adaptor is not recommanded.In this case, I want to buy here in the US the mixer kitchen aid professional 600, I will remove the 110 volts motor and will place a new motor 220 volts to make it working in Europe. Is that possible? Any internet link where we can buy all the electric components 220 volts compatibles?I am concerned because many companies over the web are charging a lot (two times) for the US equivalent kitchen aid mixer just because it's working with different voltage 220 volts.Thank you
Why not just buy a power converter for the mixer and other electronics on Amazon. They are cheap and can be adjusted for
110 - 240 and can be used anywhere in the world.
Posted on Jan 16, 2009
I want to buy a kitchen aid
and i was wondering about the voltage since i'm in Qatar
and i found this answer , Hope its useful
http://www.110220volts.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=750-WATT&Category_Code=DownVoltageTransformer
Posted on Jan 14, 2009
Is this a Kitchen Aid? Is it possible to buy this circuit board from somewhere?
This is a kitchen aid. BUT!!!! it is an international model that was sold in countries with 220 volts. Look underneath the mixer for a white tag it should have a model number and a serial number, if you can get us those numbers then we can help with the parts. Hope this helps.
Nov 05, 2014 | Food Mixers
How do I change the fuse?
Unfortunately this model is not sold here so my advice can only be general advice. Over voltage will normally blow a PCB before the fuse has a chance to blow so you should be investigating that part first before looking for a fuse it may not have. It is only going to be fixed by an appliance repair technician, preferably one authorised by Kitchen Aid. As a rule I would not expect the PCB to be repairable after double over voltage. It is probably going to need for it to be replaced. Now is probably a good time to enquire with your Kitchen Aid repairman to see if conversion to your UK voltage is economic or possible as money is going to have to be spent anyway.
May 12, 2014 | KitchenAid 32685 Mixer
A200, 1st gear had no torque(I could stop by hand). Found & replaced key on low speed gear. It sheared it again. It is just shearing it on the flat gear part, not the bevel gear part. I'm thinking it...
I have had my Kitchen Aid since 2003 and never had this problem. If this has happened to you more than once, I would call Kitchen Aid and explain the issue to them. My sister had an Issue with her new Kitchen Aid and they had her bring it for service and they replaced it with a NEW mixer. Kitchen Aid is very good with brand accountability.
Mar 01, 2014 | Hobart Food Mixers
I have kitchen aid stand mixer and i can't get the beater to attach because the button is stuck??
The button doesn't move. You must push the beater up beyond th notch and turn it while pushing up.
Jan 14, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen Aid Mixer
good day,
hope this link below will solve your problem.
kitchen appliances
Apr 08, 2009 | KitchenAid KP2671 Professional 6 Series...
Kitchen aid 110v 450watt, I want to convert to 220v
Hi guys,
The only available Kitchen Aid stand mixers on the European markets are the Kitchen Aid Classic and the Kitchen Aid Artisan.
The best way is to contact a Kitchen Aid service center / repair facility in your area.
Here is the European website of Kitchen Aid: http://www.kitchenaid.eu/eu_EU/ka/ka_europe.htm
If you bought a different Kitchen Aid Stand Mixer (like the Professional series) you probably won't find the required parts to convert it to a European model. The only way would be to use a voltage converter.
I hope this helps.
Sep 24, 2008 | Food Mixers
Noise level
its possible that you got a lemon off the factory line or they forgot to put grease into the transmission case.is there a warranty on it?if so take it back.i work for hobart which sold kitchen aid some years ago,if that mixer is less than a year old as stated,take it back or verbally speak to a kitchen aid rep. and tell them your situation.i really belive you should be able to get a replacement as long as you havent overloaded the unit or caused damage.let me know.
Jan 03, 2008 | Magic Mill DLX 2000 Stand Mixer
Can't attach beater to kitchen aid
good day,
kitchen
Dec 13, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KITCHEN AID 5 Quart Artisan Series Stand Mixer Logo
2,241 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
