Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Broken connecting rod
I have a 60 gallon 6 HP Craftsman compressor and one of the connecting rods broke. The parts catalog has the parts I need but my question has to do with the installation. Is there anything to do other than install a new piston and connecting rod, for example, is there any type of sealant or lubrication required?
  • Anonymous Mar 15, 2014
    How does the connecting rod connect to the flywheel
I broke the rod in my air compressor and cant find a place to buy a new one it is a pro source
Posted on Jan 02, 2009
  • Craftsman Master
  • 1,388 Answers
Craftsman compressors come in two flavors, light duty dry lube system or the heavy duty oil crankcase type. If you have the dry lube, your repair kit will consist of a cylinder, and piston rod with a vinyl piston ring. You should replace both cylinders and both bearings. Be carefull not to let the cylinder heads come apart because the gaskets are expensive. Make sure to turn the pump by hand to make sure everything is installed correctly.
If you have the oil bath type of compressor, you can replace only one rod, however make sure that the rod journal is smooth. Most rod failures are due to lack of oil causing the rod to melt onto the journal. This metal must be removed before installing the new rod. Use light sand paper cut into long strips and pull across journal untill clean and smooth. Use compressor oil instead of motor oil for long compressor life. enjoy
Posted on Nov 27, 2008
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
Engine turns piston not moving
if the crank shaft turns and the piston doesn't the connecting rod that connects them broke make sure that the journal the rod rides on isn't scored before buying a new connecting rod
Apr 10, 2012 | Craftsman Garden
12 gal 2hp instruction manual
You didn't give your model number so here's a possibility: If it's vibrating that much it's usually a good indicator the air pump connecting rod is broke. If it's been in storage it's possible the oil evaporated enough or it didn't have enough in it that it didn't lubricate the con-rod bearings. It would have started the first time but as heat built up in the bearing areas it could have seized up when it was shut off or broke when it tried to restart. You'll have to take the air pump apart to verify what's broke and what's damaged and what has to be replaced. Most Craftsman parts are only available through Sears (
Mar 05, 2012 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I am replacing the cylinder sleeve and compression ring on my Craftsman air compressor model 919165020. Searspartsdirect says that I need two compression rings. Is this right? My compressor only had one... This is the exploded view that I used.
67 head 65 gasket 64 reed valve plate 63 ring,this one goes under the reed valve plate 62 screw that goes thru the 61 piston 60is a ring that sets on the top of the connecting rod screw the piston with the ring into the top of the connecting rod then take the connecting rod end cap off and cover the studs with some rubber tubing.This will protect the crankshaft when you push connecting rod and piston assembly in to the sleeve that is seated in the block.The ring should be flexible enough to push into the sleeve,if not a bit of oil should help.Guide the connecting rod on to the the crank shaft.I hope this helps and thank you for using
Owner's Manual - CRAFTSMAN Air compressor 919165020, 919165050, 919165090, 919165230, 919167330, 919165221, 919165070, 919165310, 919164200, 919165060, 919165300, 919152922, 919165250, 919186430, 919155613, 919164150, 919165030, 919165130, 919165500, MG2-OILFREE, 919165110, 919167200, 919165000 -
May 14, 2011 | Craftsman Air Tools & Compressors
Need piston rod for rep0200604 compressor
A search of your model number turns up a powermate compressor. Unfortunately the piston rod is not available as a seperate part, you have to order the entire pump/motor unit. The only place I could find it was at this link:
Dec 23, 2010 | Coleman Proforce 6 Gallon Air Compressor
I am changing the belt on a oil less 33 Gallon vertical 1.6 hp Craftsman Compressor and want to know if the bolt that holds the piston rod on is left hand or right hand threads?
This is standard thread, right to tighten and left to loosen.
Make sure to put a small amout of loctite on the threads when you put it back together.
Oct 12, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Brocken valve rod ,engine backfires do I need to pull engine to rplace rod?
how do you know you broke a valve because if a valve is broken engine wouldn't run at all check the spark plug
Jun 27, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
My son-in-law has an almost new Husky WL660900 with a broken connecting rod. What could cause this and is it repairable. Dave
low oil in compressor if it broke at bottom /could be repaired if crank is not destroyed the rods are aluminum and usally just melt to crank
if this is problem muratic acid will dissolve aluminum of crank
Dec 29, 2009 | Campbell Hausfeld 28 - Gallon Air...
Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
634 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
