Question about Ruud UBHC Air Conditioner
Filter,heat ducts,and best heat we can get from unit
PLEASE HELP WE HAVE A RUUD MODEL UGTA-09EZAJS ACHIEVER 90PLUS.WE CAN NOT FIND A FILTER IT WAS INSTALLED IN OUR ATTIC IT IS NOT UPRIGHT.WE HAVE HAD MANY MANY PROBLEMS WITH OUR INSTALLER.WE HATE TO CALL FOR INFO.BUT FEEL ALSO THAT WE AT NOT GETTING THE BEST HEAT FROM OUR UNIT.ANY HELP WE WOULD LOVE TO HAVE.ITS ALL VENTED IN ATTIC WITH BLACK PLASTIC HOSEING.THAT WE AT TRYING TO KEEP ATTCHED TO VENTS
  • 96 Answers
As for a filter if there was one installed it will be somewhere between the unit and the inside livingspace and are the black plastic supply vents wrapped with insallation or not ,if not they are the wrong ducts if you need more help just e-mail
Posted on Nov 11, 2008
Ruud Achiever 80. How do I replace the filter?
if its not on the outside of furnace where cold air duct goes in, and you dont have a high efficency filter, which may not look like what your used to, it will be on the inside of the bottom door where blower is located. If its a standard filter, it should be changed monthly, so you may have a really really dirty furnace and this requires immediate attention to avoid fire hazards and part/blower failure and overall efficency.
Dec 22, 2011 | Heating & Cooling
My sister has a Ruud Achiever High efficency heat pump Model UPLA-049JAZ Serial #6408-M389910353 they just moved into this house in ND and have no information on this system..Over the winter it was...
There are 3 possiblites
1. you have a bad defrost board or defrost sensor.
2. Your low on Freon.
3. Your coils and/or your Filter is dirty.
May 01, 2011 | Heating & Cooling
2 Rheem Protech 500 thermostats, 1 upstair & 1 downstairs with a Rudd Achiever 90Plus gas furnace. Thermostat downstairs works fine but upstairs one cycles fan on and off 2-3 times during heating...
Have you checked to make sure that all of the supply registers are open, the air filter is clean and nothing is blocking the return air grill?
It almost sounds like you could be cycling on a limit switch.
Usually on gas furnaces, the blower is controled by the onboard controls, in the cooling mode the thermostat will control the blower.
I would be looking past the thermostat, at the furnace it self.
I hope you find this helpful. If you continue to experience problems, please let us know and we will dig deeper. :)
Paul
Feb 13, 2010 | Ruud UBHC Air Conditioner
I have a RUUD Achiever heat pump. Where does the filter go? I don't see a slot for it. I can't even tell what size filter it takes, since there is no defined slot.
it would be at the air handler portion of things (the unit inside) you might have to take off the lower door to access it it would be located at the bottom of the unit or somewhere in the duct work before that point look for spots that say airflow and will show an arrow--->
Jul 12, 2009 | Ruud UBHC Air Conditioner
A different smell coming from the heat ducts. I can't figure where the smell is coming from. I have Ruud achiever plus 90 furnace.
There can be several causes for odors in a unit. If you have just started turning the air on, you may have an issue with too much moisture in the coil and supply plenum causing mold to accumulate and grow. Also ducting can come apart or be chewed open by critters allowing air to be drawn in from the attic or crawl space depending on your configuration. These are the typical smells.
Apr 08, 2009 | Ruud UBHC Air Conditioner
Replacement of filter on Ruud Achiever series heat pump/AC
You must first remove the blower compartment panel. The filter should be in there. However, since this unit is in a crawl space you may have a return air filter grill. Look at your return grill. Does it have a filter? If not does it have latches so that you can open it? If so measure the opening and install a new filter there. I hope this helps. Please don't forget to give me a Fixya rating.
Feb 21, 2009 | Ruud UBHC Air Conditioner
How do I change the filter in my Ruud Achiever series
I'd look in one of 2 areas.
1. often there is a central return in the house. This is the place where the air gets pulled back to the unit and is likely very close to your thermostat. Check for a filtered louvered grill there and see if your filter is located here. If so, you can access the filter by opening the filter frame with a screwdriver or even a coin.
2. Otherwise I would expect that your filter is on the return-air side of your air handler (where the blower is) Older models have the filter actually inside the air handler in the blower compartment. Newer models may have a small separate filter door. I'd look in these areas.
hope this helps
ghoff
Filter Placement Ruud UBHA
hey brad first you need to indentify wich is your supply and wich is the return after you have done that the filter is allways on your retun side however not allways is the filter set up at the air handler sometimes its in a duct sytemn on the ceeiling or wall hope you find it
Jul 05, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
97 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
