Question about Matsonic Computers & Internet
Boot from usb
I set the boot sequence to usb. it goes to cd
Try to disable the other boot device, or you simply need to first boot the usb then the rest disable.... if the problem still occur, you might not save the setup utility options properly or the flash bios/cmos failed to save due to a weak or a cmos battery checksum error...
Posted on Nov 11, 2008
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Hp g60-440us won't boot from external cd
Set the boot sequence in the BIOS to boot from USB if your external cd is usb.
Jan 30, 2014 | Computers & Internet
When I boot I get the blue intel screen with all choices but nothing will work when I click
Set your boot sequence to cd or usb and put in your windows cd or usb and there should be a repair option. Or you can reformat the drive and do a fresh install. Whats happening is the bios is not talking to the OS it could be you need a bios update but chances are reinstalling the OS will work.
Nov 07, 2017 | ASUS P5LP-LE Motherboard
My Dell Inspiron worked fine yesterday, but after charging the battery over night and attempting to restart it, all I can get is "operating system not found." What can I do to get my...
What the computer is telling you is that the device it accessed does not have a Operating system. If you have your boot sequence set in your BIOS to access a Floppy disk first, a CD drive second a USB drive third and then your HD last, or any sequence above, then for instance if you left a floppy disk in your machine and the computer was given instructions to check the boot of that first, then it did not find a system. Same goes for CD if you left a CD in your system.
First make sure that you did not leave any items in the drives, and try again. If that does not do it, go into your BIOS, F2, upon boot up and set your boot sequence. If you put your hard drive first and the machine still does not boot up then you have a corrupted boot sector on your drive and must do other things up to re-installing your system.
Jan 08, 2011 | Dell Inspiron Mini 10 Notebook
Boot up does not load to login prompt. It loops after not detecting D1.D2.D3 and goes right back to the Start Windows Mormal prompt
you will have to change the boot sequence in the BIOS.
preee F2 or Del to enter the BIOS - you can change the sequence, set the first Boot 1 = DVD/CD, boot 2 = Hard drive
press F10 exit and save > ok
next time it will iuse the DVD/CD to boot first.
if you set the boot to b1 = Hard drive & boo 2 = DVD/CD......the hard drive boots
hope this help
merry xmass
Dec 21, 2010 | RaidMax RX-450K 450W ATX12V Power Supply...
How to boot laptop from usb flash disk
When u just turn on your laptop go to bios bios settings change the boot priority to USB and restart before you restart connect your flash drive to ur will ask boot from flash drive press any key....n contiune...hope this helps
Mar 11, 2010 | Computers & Internet
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Inspiron 8100 Boot Problem
i think you did not choose proper boot sequence from the bios.
plz choose another which indicate that your cd rom.
another way is that you when boot the pc press f9 key many time then it will ask you for boot device.
Nov 14, 2008 | Dell (0K724) for Inspiron 8100 40 GB Hard...
Computers & Internet Logo
149 people viewed this question
Top Matsonic Computers & Internet Experts
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
