Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
WinTV-HVR-1600 Tuner card to DishNetwork receiver
Can i connect a dishnetwork output cable to the TV connector of a
Hauppauge WinTV HVR-1600 tuner card
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Posted on Feb 28, 2009
Dell? Hauppauge WinTV-HVR-1250 TV Tuner "IR Hardware not detected" message during setup
Make sure you have the remote sensor plugged all the way into the connector on the card. Also check your taskbar for the "remote" icon which confirms you have "irblaster32.exe" installed.
Jan 27, 2010 | Hauppauge WinTV-HVR-1250 MC - White Box...
I have a HP Media Center PC 470n. Is there another card just for that PC. I have the wintv- hvr 1600,not as happy as I thought I would be.
You can use any capture card you want as long as you have a slot on the mother board. Media Center works with almost every capture card.
Having said that, i found hauppauge a great capture device what was it you didnt like?
Jan 06, 2010 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Nov 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have a Hauppauge WinTV-HVR-1600 running windows XP on ATT uverse I can not get the TV Tuner card to pick up any channals I have tried the bundled SW and a thrid party software results were the same. I...
Most likely, all stations in your area have switched to Digital Transmission, and your card can no longer find any. If that is the case, then you need a new card (they are not convertable) sorry.
Aug 19, 2009 | HP Hauppauge WinTV-HVR-1600 NSTC/ATSC Tv...
Tv tuner
Basically what I can see from what I have read one had dual tuner capability and one is set up for PCI Express. Both look like great cards.
http://www.hauppauge.com/site/products/data_hvr1600.html
http://www.hauppauge.com/site/products/data_hvr1800.html
Thanks
Armymason
Feb 24, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Nov 19, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Oct 04, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No color from VHS on DVD/VHS player
There may be an input selection between Composite and S-Video that needs to be toggled in your Hauppauge software.
Your Hauppauge card may also be in the wrong signal format mode (NTSC or PAL). Your source device and your Hauppauge card need to be in the same mode (both NTSC or both PAL) for the capture to work properly.
If your NV-VP33 is a SCART output, then you may need to check your SCART adapter and your device as not all devices output both S-Video (Y/C - two signals) and Composite (CVBS - one signal) type signals.
If your SCART adapter has both Composite and S-Video outputs, try the other one.
And finally... if you're playing an NTSC tape/DVD in a PAL player, it doesn't mean the output is true NTSC 3.58. Most times it's NTSC 4.43 which is OK for TVs, but NOT okay for video capture devices. Video capture devices need true NTSC 3.58 to sync the color carrier properly.
Apr 29, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Wintv stuttering when watch channel, but is fine when record it
Further update: Have downloaded SageTV, and it works fine with the Hauppage card. Is definitely a software problem. Have also tried total uninstall, reinstall, with same results. Also downloaded GBPVR, and it also worked with the card.
Jan 03, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
1,091 people viewed this question
Top Hauppauge Televison & Video Experts
Iqbal Husain
Iqbal Husain
Michael Galve
Michael Galve
jason
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
