Question about Panasonic PT-47WX49 47" Rear Projection Television
Lines in screen
I purchased a Panasonic PT-47WX49E 4 years ago. I have lines across the screen. It almost looks like a vertical hold problem. The number and size of the lines vary, but always go completely across the screen from right to left. I think what contributed to this problem was the fact that i had the TV in a room of the house that was in direct sunlight. It was a sun room with no shade, and I was completely stupid to place the set there. The tv shuts off on it's own if it gets hot, but not from where it is. the fact that it was in a bad area made it perform like this. As long as I keep a small fan behind the tv, it'll work fine. My only real concern is the lines in the screen. I hope you can help me here. Can you give me a part # and a place to purchase the part. I live in New Hampshire. john
  • denrab Dec 31, 2007
    Would you use the same replacement parts (C7136 and C7154) for PT-47WX51E? I have the same exact issue, but a different model than the PT-47WX49 identified by the original poster.
  • shonecs Feb 25, 2009
    violet vertical lines from left to right all along the screen in kodak C713
C c c c c c cc
Posted on Dec 22, 2007
  • 4 Answers
Replace C7136 and C7154. They are both very leaky if not open. It is a common symptom with this model. I think they are 47 mic. caps. at 16 volts.
Posted on Jun 15, 2007
Pink and green diagonal lines rollng across the screen??? panasonic 42" Plasma . Only purchased about 3 years ago - but been used very rarely.
Have you tried lifting the ground on the TV? That set has a grounded (3-prong) plug and sometimes sccrolling lines can be caused by a ground loop in your power lines.Are the green and purple lines very short, like just a few rows of pixels tall, or multiple inches, like 3 - 8 tall?
May 04, 2011 | Panasonic TH-42PZ800U Plasma TV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Vertical lines across screen on my panasonic tv PT-61LCX65
Try setting a portable fan aimed toward the cooling vents on the back of the set. If this eliminates or reduces the occurance of the lines, this means a circuit that controls the off/on of individual pixels has developed a thermal problem. This circuit is ordinarily loacted on the main circuit board and is likely to degrade further. You might inquire at the Panasonic service center if they have an exchange program in place and they will probably be able to confirm my suspicions.
Aug 09, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Replace c7136 & c7154 on A board This should clear up your problem
Dec 11, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
can't tell from your video but you are describing a bad cap perhaps a 160-250 volt in your power supply check your supply for ripple
Sep 27, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasoic PT-47WX49E
Jan 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Vertical lines and big red spot on Panasonic PT-56LCX66
Return it my friend, it sounds like a problem on the display panel driver board, and boy is that expensive to replace! Good Luck
Jul 30, 2007 | Panasonic PT-56LCX66 56" HDTV
PT-47WX49E Service Manuals
scott iam in need of one too would you PLEASE add me to your list Thanks so much
Apr 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
94 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
