Question about Whirlpool Washing Machines
I have a whirlpool wfs1276aw which is only weeks old the machine started to go to pause when it was supposed to be emptying. the manual says that the filter requires cleaning but when i unscrew the filter i cannot get it out to clean. the cap actually comes away from the filter and even then i can't remove the filter
  • 2039 Answers
SOURCE: Stuck filter screen screw on DeLonghi BAR32
i got a saeco vienna digital i got the same problem that screw jam the same as our i clean the filter with water and air if you whant to try something try to soak in decalcifier it gonna melt the calcium cheers
Posted on Jan 16, 2008
  • 1294 Answers
SOURCE: washing machine will not drain
You shd check out your pump, refer
to manual. There shd be some block there.
Posted on May 09, 2008
  • 3 Answers
SOURCE: i cant get the filter out of my washing machine help please
DO NOT keep trying to force the filter, especially not with pliers! Mine wouldn't turn, and when I eventually got it out it was because a coin was stuck in there! Rattle it left and right many times to free the coin, and eventually it will come out, but if you force it, either the plastic filter will break or the coin. Guess which?!
Posted on Oct 29, 2008
ttdesignbilt
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
I had the same problem and figured if the lint sensor is clogged, covered or otherwise gummed up with lint, dirt, hair, etc then this will continue to happen regardless of wether the lint trap is clean.
So I took my compressor and blew out the slot where the trap slides into...stuff flew everywhere (so watch your eyes or wear goggles). I then vaccumed it up and did it again... and again and again each time loads of stuff came out. Once nothing blew out I loaded the dryer and have not had the problem since...
This makes sense right? so if you can try this solution.
Posted on Jan 24, 2009
Sometimes a bigger object might block the filter knob, and make it impossible to screw out. Then the only way is to remove the end of the sump hose attached to the filter and remove the stuck object.
(In my filter this object was an Umbraco key) :-)
Posted on Feb 09, 2009
Our Maytag Centennial Commercial washer is exactly 3 weeks old today. I've done about 12 loads in it so far, none of them heavy. I put in a load today, and it wouldn't start. I unplugged it
I would suggest that as it is a new unit , it is covered by warranty so why don't you call the service agent for a warranty inspection and fix rather than loosing your cool
there is nothing you can do while it is under warranty as any fix by other than authorized service persons will void the warranty
Oct 02, 2016 | Maytag Centennial 3.2 cu. ft. SuperSize...
Whirlpool wfs1276aw error F06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
open the machine and use a dry paint brush
give the motor a good clear off of the carbon dust spent from the brushes
you should while your there take the brushes out and check there condition is ok
they should be long ie longer than 1/2"
if not replace them
as your getting issues i would replace them
and dont forget to brush off the bad carbon dust
it gets everywhere leading to motor issues
as most sensors are low voltage leakage of current accross the dust can upset low voltage stuff easy
and also leed too your homes mains tripping etc
just from dust
i find most often brushes have some life left
but treat it too a new set
as its a bit upset by the old ones anyway
perhaps they have delaminated also
Dec 02, 2014 | Whirlpool Washing Machines
I have a whirlpool wfs1276aw. It suddenly stopped working displaying the error F06.
pl.check the current and voltage with the meter and continuity test after unplugging the mains chord,which may give some iferrence
Whirlpool 6th sense wont start cycle
I have the same problem. Look at the previous post, it seems to be the motor brush worn out. I've opened up the machine and checked. The carbon brush remains very little. I am trying to find out a replacement brush
Dec 27, 2013 | Whirlpool AWM6100 Front Load Washer
Whirlpool WFS1276AW bangs loudly when rinsing and spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 06, 2010 | Whirlpool LHW0050PQ Front Load Washer
Last night I tempted to clean the large duet washer with the chlorine program. After starting, I realized I only had clorax bleach for colors and reluctantly used this. Large suds formed. I paused/cancel...
Drop your drain hose to floor level with bucket under it this will drain with no power applied , pour in as much water as you can to flush it out / clear pump .After all suds clear refit / restart ..Should now fill, wash/ empty and spin...I hope ...
Apr 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio Washer Error message code F1
The following list of codes indicates a possible electronics communication problem with the washer:
Cabrio washer - F1, F2, F40, F41, F42, F50, F51, F52, F53, F54, F72
To remove the error display, press Pause/Cancel twice.
PLACEHOLDER FOR ART
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Please do not forget to rate and comment about your experience with fixya today.
Aug 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool duet front loader
Sounds like you have a board problem. If the machine is only 1 month old, you should really have a warranty agent look at it. You don't want to do anything that could void the warranty.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LSR7233000 Washing Machine
HI thanks for your question. i would look at the lid switch, you said you had an off balance load. that could have broken the lid switch. replace it thanks
Oct 26, 2007 | Whirlpool LSQ9610L Top Load Washer
Washing Machine won't empty water during the cycle
does the timer advance by itself? if not the problem is your timer not advancing through the cycles. if timer does advance then being 14 1/2 years old it could be the motor. start the washer and mark the beggining where the timer starts. whatch it to see if it moves if not then you need to replace your timer
Jan 30, 2007 | Whirlpool LSR9434PT Top Load Washer
Washing Machines Logo
159 people viewed this question
Dan Webster
Dan Webster
Sal De
