Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ge true temp stove top burner wont stay on
Cut on high but wont stay on
keeps cutting off
help
    President:
  • GE Master
  • 2,651 Answers
Dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Posted on Nov 11, 2008
GE true temp flat top stove/oven isn't working at all, there is power to it, if you turn the burner dial on the clock/electronics turn on but nothing works. turn dial off electronics/clock turn off
sounds like you are missing one leg of the 240V power supply... first thing is to reset the circuit breaker. Then, meter how many volts you are getting at the terminal block where the power cord bolts on... Help Me Find My Model Number RepairClinic com, GE Terminal Block WB02X10606
Jul 26, 2016 | GE Kitchen Ranges
GE Spectra burner stays on high
if this is the one with the auto temp burner , defined by a sensor sticking up from its center , this maybe a normal condition for it without a pan on it , as I had one of these come on my new stove , as being a exe chief for 6 years id always set my flame height before setting the pan down , this feature took me some getting used too !!! to say the least !!
but now that im used to it , its great I love it , no more burnt on messes , works great with caramelizing things !!!
Feb 08, 2016 | GE Kitchen Ranges
How do I keep the burners on at medium heat when I am making carmels so they get to the stage where they become caramels. My burners kept shutting off, so I had to turn them higher and when I got don
Is it the electric glasstop stove with the smooth top? If so, the burners aren't actually turning off. They're red until they reach the right temp and then they go dark to maintain the temp. If they stayed red the temp would keep climbing. I used one a while back and I remember it doing that. You didn't give much info, so that's my guess. I think most electric stoves do that to some extent, though. If it's gas, however, I'd call a repair guy.
Oct 01, 2017 | Kitchen Ranges
On our glass top GE Profile stove, the burners do not stay on - they keep turning off and then on again before coming to full temp. Extra long time, for example, for water to boil.
They cycle off once they have reached the temp that you set, then come back on to keep that temp, my suggestion is increase the set temp.
Dec 01, 2013 | Cooktops
I have a GE XL True Temp gas range/oven. None of
your stove must be plugged in for the auto-pilot to work .do you hear a ticking noise when you turn on a burner?
Oct 07, 2009 | GE JGBP28 Gas Kitchen Range
GE True Temp flat top stove - heating with switch off
This happened recently to my stove... heard a funny sound and then the burner I was not using suddenly started heating up with the switch still in of position. It appears that the problem is the burner switch. I've bought a new one...however I didn't note the order of the wires before removing the old one... and now can't get the new one hooked up right! Part is only around $25.00.. just be sure to mark where the wires go before unplugging them.
Sep 05, 2009 | GE Kitchen Ranges
GE True Temp oven won't turn off.
The sensor is a part number WB23T10002 and goes for about $60. The paper inside the control area of the oven will state the normal resistance values of it. (probably about 1080 ohms at room temp, about 2650 at clean temp.) If you cut a lead to it, you would just get a F3 code, and if you cut the other and wire them together, just get a F4 code, so that wouldn't help diagnose the problem, but if you could use an ohm meter on the probe it would. BUT the oven should not come on without it being set to bake, SO I conclude that the ERC is indeed the problem (with the welded electrical contacts), which is a part number WB50T10043 which might go for about $125 or so. If you are careful when you replace it, you can probably peal the faceplate (part # WB27T10125) off and reuse it, so you should just need the ERC.
May 05, 2009 | GE Ovens
GE Profile stovetop w/4 burners doesnt stay hot enough to cook on anymore
I would check to see if you have 220 Volts to the stove, even if you have only one leg with 110 volts to stove it will let the burners get half hot. with out the model number i don't know about any censers. The flat tops have temp sensors on them. but not that operates for all four. I would check at wall receptacle first for 220 volts first but only if you are qualified to work with electricity REMEMBER it can injure or KILL you.
Feb 05, 2018 | Kitchen Ranges
Burner temp.
If set to high, burners should remain on. If set to medium high let's say, they would be on for maybe 70 percent of the time, off for 30 percent of the time. If set to warm, they might be on only 10 percent of the time, off 90 percent. There is a high temp limiter which could turn a burner off. If you have a burner on high and are cooking on that burner and it goes off, the high temp limiter may be faulty. It is an integral part of the burner, and would require replacement of the offending burner. Burners are individually replaceable after lifting up the glass cook top.
Oct 19, 2008 | GE JBP66 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
485 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
