Question about Kitchen Ranges
CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
Maytag gas stove CRG9700 Model AAW purchased 1995. Temperature fluctuations in oven. Replaced temperature sensor. Now getting hot spots - one side of oven really really hot, the other side cold.
HELP!
  • sandy655 Nov 11, 2008
    Hi Aborcass,
    Thanks for the solution. Replaced the ignitor a year ago. Could it go again in as short a time as a year?
  • Anonymous Dec 01, 2008
    I was told by the serviceman that the sensor never goes bad but the module does frequently. I have a cold oven with phoney temperature readings also. He mentioned the sensor should be 1077 ohms at room temperature and mine was right on the money. Still debating whether to fix the thing in such a piece of Maytag junk. First time we used the oven cleaning function it burned the face off the front. Knobs have lost their markings and the top chips if you touch it with anything hard....pretty junky after their old reputation.
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Posted on Nov 11, 2008
  • Ron Coons
    Ron Coons Nov 11, 2008
    sure could be, ignitor is an electrical part no rhyme or reasonas to how long it will last 12400035 kit comes with all parts and instructions to install
My oven temperature fluctuates widely (50 degrees) in both directions and won't hold a consistent temperature. I see from the manual that I can adjust the temperature up or down, but this won't address...
Try replacing just the thermocouple. You don't say how old the oven is, but the thermocouple is the device inside the oven that takes a beating (especially if it is a self clean model) and needs to be replaced every few years. A failing thermocouple allows wide temperature fluctuations.
Nov 18, 2017 | Whirlpool Ovens
Maytag gas stove model CRG9830CAE the oven will not work
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, the igniter needs to be replaced. Good luck.
Mar 27, 2010 | Maytag Kitchen Ranges
Whirlpool range 465 model # sf369lemo oven temperature
no stove holds a true temp they all fluctuate temperature depending on how well it is insulated.
Feb 06, 2010 | Kitchen Ranges
Maytag MER5730ACW Stove.F3 fault code.
hello there
Please go thru this list of the fault codes for this appliance it will tell lyou what to do for the fault or what part needs to be replaced
MAYTAG FAULT CODES
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components. Find Parts clear.gif
Jan 13, 2010 | Maytag MER5730 Electric Kitchen Range
F-3 Error code Maytag Wall Oven....
Jun 24, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
The display at top of stove is showing "F1" and continuously beep
or
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Whirpool Gold Acubake gas stove model GW395LEPB02 purchased in Oct 2006.When I am baking on 350 the oven jumps to 500 and smokes is everywhere. The number E2F3 shows up on the control board. What is the...
This error indicates the Oven temperature is too high,
You will need to replace the Oven temperature sensor (RTD).
This part can usually be replaced from inside the oven.
Jun 22, 2008 | Whirlpool Kitchen Ranges
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Kitchen Ranges Logo
926 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
