Question about Dryers
Door rubber for Defy Sensimatic 45 Tumble Dryer
Hi, we have a Defy Sensimatic 45 Tumble Dryer and have just bought parts from South Africa, only to find that the drum rubber "seal" also needs replacement now that we have stripped it to replace the parts. Can anyone help with where we can find this door rubber here in Australia?
5 Suggested Answers
  • 139 Answers
SOURCE: Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Posted on Jan 18, 2008
  • 185 Answers
SOURCE: Tumble dryer door seal
you should use high temp glue
Posted on Mar 24, 2008
Illeagle
  • 525 Answers
SOURCE: User Manual : Lavatherm tumble dryer T3
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=31378668&sid=MMHSx20070515x00001a
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 24, 2008
reg501
  • 413 Answers
SOURCE: rubber door seal
Try here: http://www.searspartsdirect.com
Posted on Jul 12, 2008
SOURCE: fit felt drum seal to zanussi td4212 w tumble dryer
I take it that the belt is ok and the drum is turning.The heater comes with thermostats fitted as a complete part.There is an overload safety thermostat which is situated inside the drum and above the door,it is held in place with a self tapping screw then prise open the plastic cover and then the thermostat will pull out,if replacing remember to refit the small gasket.Have you checked the filters and exhaust hose for any blockages as this will affect the heating.
Hope this helps
Posted on Jan 22, 2011
I've bought a Defy Autodry tumble dryer, but the black "rubber" on the door keeps coming out, which then pushes the door open, and the machine then automatically stopped. Can i just replace...
A TUBE OF CONTACT CEMENT WORKS WONDERS ON THE SEALING RUBBER - JUST FOLLOW THE INSTRUCTIONS ON THE TUBE . IF ITS GOOD ENOUGH FOR DOOR SEALS IN THE AUTOMOTIVE INDUSTRY ITS GOOD ENOUGH TO HOLD YOUR DOOR SEAL IN PLACE - GOOD LUCK.
Jul 26, 2011 | Dryers
Thank you,
Dave E. (Illeagle)
Jun 24, 2008 | Dryers
Dryers Logo
127 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
