Question about Frigidaire Ovens
Oven and and command center are totally out. Range works but that
It worked fine last night, now it won't. Help!
    Scholar:
  • 112 Answers
You can check for an internal fuse that could be the cause, but in most cases, this is due to a faulty control board.
Posted on Nov 10, 2008
"Amanda" ARDS802E. Why won't it heat?
Becky, it sounds like you have either a failed ERC or Electronic control board (Y0315030) or a bad limit control switch (31933003). If it's the ERC it's likely bad relay(s). If your clock is powering up and you see the clock then that lets us know that you are receiving power to the oven. If it's the Limit Control, then you will need to replace that approximately $60. It's inside the oven and prevents the elements from getting hot if it breaks. If it's the ERC then you can have it repaired for $99.99 from The Repair Shack. The link for the repair service is: Repair Service For GE Oven Range Control Board Y0315030. Hope this helps!
Nov 29, 2015 | Ovens
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Hi Last night my oven just stopped working while I was baking. All the lights and clock went off and oven/broil controls are inoperable. The burners (and the electric ignition) continue to work fine. I...
You have a bad EOC electronic oven control unit, They are readily available from any parts house. They do not have instruction but are not difficult as it is just a few screws and swap out wire for wire. It may be a good idea to buy it from a vendor that allows returns of electrical items. Many do not allow returned electrical items. Please rate my answer and any comments are welcomed at least good ones:) Good Luck, Mastatech.
Aug 25, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153992&diagram_id=1251523#d1251523
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
My oven display is beeping and blinking 'PBR' on the display. What does that mean?
I had this same problem last night.. I have been having problems with the oven shutting off on preheat.. That sort of stopped. Last night lost power to the house. When it returned the oven was beeping and flashing PBR. I turned off the breaker for a few mins. last night and it returned. It was bugging me so much that turned it off the whole night. Woke up this morning turned the breaker back on and it stopped. I don't think this is the total solution. I am thinking that eventually I am going to have to replace power board in this oven. Hope it works!
Sep 23, 2009 | Jenn-Air Ovens
Oven not working
you would have to check the element for continuity. Also the oven sensor could be suspect and should ohm out at 1180 at room temp. if both those are ok then main control is probable. without schematic it would be hard to say for sure..there may even be a safety fuse blown.
Jun 13, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Elements in convection oven won't heat
DO you have a model number for that. I'm almost sure it's a thermal fuse in the back of the oven. Usually they go out during or after cleaning but that would shut down both elements. If you have the model (usually by the inside door look all over and up in the cavity) Then if you go to this link
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
It will show you a breakdown of the oven and where it is. If you give me the model I'll show you what I'm talking about. Good luck.
P.S. if it the fuse it's a cheap fix, little hard to get in back of the oven but cheap!
Mar 04, 2009 | GE Ovens
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Thermador Oven won't heat after running self-cleaning cycle
SOunds like you need to reset the oven high limit switch. It should be located behind the grille obave the oven opening and below the control panel. There should be about 4-6 screws you need to take out to remove the grille to gain access. Turn the power of to the oven at the circuit breaker, then rech in with a screwdriver and push down on the little red button in the center of the hig limit until it clicks. the high limit should be about as big around as a quarter and have a wire going into one side and out the other. If this keeps tripping, you may have a bad cooling fan. When you run a self clean it should also run a fan to cool the components. You should be able to feel a breeze coming out of the bottom of the oven when the cooling fan (not the convection fan ) is running. If this fan doesnt run, it will trip that switch. Hope this helps!
Dec 08, 2006 | Thermador C301U Electric Single Oven
Ovens Logo
42 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
