Jensen RCS70 backup camera monitor,,,,was working fine,,,now has a straight white line
2 Suggested Answers
SOURCE: Jensen VR187 radio/backup camera observation monitor won't work
In the manual look on page 10 step 10. You have to use a ball point pen and straightened paper clip (better) to reset the unit. There is a small hole at the lower left of the Volume knob. That's where you insert the paper clip.
Posted on Dec 21, 2009
Get the blue and white lines of my screen
you can go to the service center may be your display is not working properly
Sep 13, 2013 | Fujifilm Finepix Hs30exr black Digital...
My jensen dvd player mvb85
It still plays but no sound... probably the line going to the screen, but check the settings and try a CD that worked before....
Keep me posted...
Feb 06, 2008 | Jensen 8.5" Overhead DVD Player Package...
White line vertically on my monitor just showed up but computer seems fine
The problem seems to affect only the monitor whih means that all of your data is safe (in any case make a backup, you never know).
You should bring your computer to repair service. If your computer is in warranty you will have a free repair service.
Feb 05, 2013 | HP Compaq nc6120 Notebook
Samsung LD220 - background (plain blue) has continuous horizontal wavy lines that move up the screen. As if straight water ripples are going up screen. But, pop-up windows display fine since they are...
There may be a few issues her, try changing the contrast andbrightness of the screen, this can be done by using the buttons on the monitor,check any documentation you have if you're having trouble. If this doesn't fix it could be a monitor problem for your videocard itself. Try using another monitor,if possible, to test your video card or try your monitor on another pc/laptop. If the monitor works fine on another machine then chancesare it's a problem with your video card, it may even need replacing.
Mar 02, 2011 | Samsung LD220 22 inch Monitor
I have a jensen cd6112 radio vol control is not working also will not change bass/tre/ or speakers.Tried reset button but no change .Vol knob won't do anything.
I was installing a speaker and while drilling a spark flew. Didn't think anything of it and finished instalation. When finished the audio didn't work on any of my speakers. I have a jensen cd6112 and the unit seemed to be fine. Tuned in, the lights came on and everything. I hooked a radio straight to the speakers to see if they were blown and they worked fine. Is there a fuse in line with the speaker wires? I would hat to buy another jensen unit and the same problem exist. Any help? Is the jensen unit bad?
Jan 05, 2010 | Jensen Car Audio & Video
My monitor sony ssm-721 rolls until it warms up or
Fixed mine! Take off the monitor from the dash. Take the cover off the monitor. There are four seperate white plastic turn dials available inside the case. Each of these have seperate controls the ones on the top are for brightness and focus while the ones on the bottom of the casing are for vertical and horizontal hold fine tuning, use a screwdriver to adjust. Save you money and do this yourself it's easy as pie.
Nov 14, 2009 | Sony Home Security
Aug 09, 2009 | Audiovox Jensen JTFT-250 2.5 in. Handheld...
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
What does the green/white wire connect to on my jensen vm9312hd? Says it is reverse +
Rear View Camera Input: The VM9313 features a composite video input and a green/white wire lead attached to the harness for connection of a rear view camera. If a rear-view video camera is connected, the unit is on, and the TFT monitor is retracted inside the unit, the TFT monitor automatically moves into the viewing position and Camera modes is selected upon shifting into Reverse gear. When shifting into Drive gear, the TFT monitor is retracted back inside the unit. If the monitor is already in a viewing position and in display mode, the monitor automatically switches to Camera mode upon shifting into Reverse. When the reverse driving stops, the monitor returns to its original input display mode. You can choose for the monitor to display a Mirror mode image or a Normal mode image from the rear-view camera.
Jun 21, 2009 | Jensen's VM9312 Car DVD Player
Horizontal white lines
if you cant adjust the A1s then it sounds like the F.B.T. is up the swanny (faulty).
Jun 01, 2007 | Jensen Q2049J 20" TV
Televison & Video Logo
351 people viewed this question
Top Televison & Video Experts
