Question about Sony KP-53XBR45 53" Rear Projection Television
Tv wont turn on the timer/standby light lickers
TV was working fine until today I got home turned the power on and it had no video or audio only the red timer/standby light was flickering. I hear a clicking sound when I turn it on but nothing happens. I took the tv off the surge protector and pluged it in directly but no change. I dont really know what the situation is and it had not done this before it had turned off by itseld before but you could turn it on no problem.
  • 1 more comment
  • kreig Nov 11, 2007
    same problem as the other. led red light turns on and off but no sound or picture. Power supply maybe ?
  • Anonymous Apr 19, 2009
    standby light flickers but no picture or sound
  • gbrodt62 May 04, 2009
    Will ot turn on, hear cilck then nothing.
Open up the tv. On the boards that have connectors, de-attach all of them, one by one. Use a can of "duster" to clean out each receptical, then re-attach each piece. Do this to each and every connector on the boards inside. This should solve the problem.
Posted on Dec 22, 2007
I have a LG LED TV 55LS4500UD that no longer works after a storm. It won't turn on and no standby light. I have pics of the circuit boards. I would like to know which board to replace?
Power Issues Troubleshooting
*NOTE* LG & Vizio TVs must be plugged in for 5 minutes before it will turn on*
1. Inspect ALL Ribbons and connectors. Any tears or bad connections between boards must be replaced FIRST
2. If you have any of these boards, it should be the first board to be replaced
A) T-Con Board - Video Problems (No Video with standby light on, audio but no video, grainy, distorted, or color problems in screen)
B) X or Y Buffer Board (Plasma TVs only) - Standby light is on but no power
C) Backlight Inverter / LED Driver - No Video with standby light on
3. Main Video Board
- Either video or audio does not work (if no T-Con in TV. If audio but no video it is T-Con)
4. Power Board - No power AND standby light does NOT turn on. If standby light is on try other boards above
5. Panel - No power, distorted picture, lines, slow motion, half screen, faded in / out. Panel problems are usually not worth replacing the panel.
Apr 11, 2016 | LG Televison & Video
Tip
Tv problems lg and vizeo
3. Main Video Board
on May 22, 2015 | LG Televison & Video
Vizio 55" smart tv e552vle no power or standby light!
Have you tried un plugging the TV for 10 minutes and seeing if that clears the lock up? This is a software issue I'm sure.
Mar 23, 2017 | Vizio L32 32 in. LCD HDTV
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
Samsung flatscreen wont turn on but red light is on showing power ..my son used sleep timer last night
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
ONLY USE DOWN NAVAGATION KEY until RESET is highlighted
then PRESS RIGHT NAVAGATION KEY the tv will reset
PRESS STANDBY TO EXIT
the tv will need retuneing after
hope this helps
Dec 19, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Playstation will not connect to TV, audio or video
Put your PS3 in standby mode (hold the power button until the light turns red) then release, and hold the power button again for about 10 seconds, or until the light beeps a second time. When the PS3 restarts, it should display using whatever it finds first.
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
Can't get my Panasonic LCD out of Standby.
I only have two solutions. Either, turn the tv on from the tv. or try checking the tv connection. If that doesnt work maybe the remote is out of battery.
Sep 14, 2009 | Televison & Video
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv won't turn on
i can' turn on my sony tv . no lights are blinking. nothing. could something when it was moved.
Dec 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light blinks and tv won't turn on
Four blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Dec 27, 2008 | Televison & Video
Televison & Video Logo
318 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
