Question about Loewe Articos 55 55" Rear Projection Television
My Loewe Articos 55 will not power up
The red light changes to green then after a minute or so it turns back to red. IN the mean time I can hear the sound of the cable through the receiver so I know everything else is working fine.Any advise is welcome.Thax
  • zpirani Jan 20, 2009
    I have the same problem. I just replaced the old lamp myself. It was pretty straightforward to replace (maybe I did not do it correctly). But still no picture. It is very frustrating. Any specific instructions on changing the lamp on a Loewe would be extremely helpful.
  • Anonymous Feb 22, 2009
    I have had a similar problem in the past and it turned out to be a bad ballast board.
    Hope this helps!
  • Loewe Master
  • 5,138 Answers
If you have sound and Lamp is not turning on your ballast Board is Bad Call Encompass Parts 1-800-638-3328 or UED 1-800-648-6657 and Both companys have websites visit them online .
God Bless and have a wonderfull Day.
Posted on Nov 14, 2009
I have a Loewe Articos 55 HD, when we turn it on it makes a consistent loud buzzing noise. We spoke to a Loewe tech over the phone and he said that it would cost in excess of $2500 to fix - which seemed a...
replace the color wheel and remove the fan blowing on the engine, its forceing dust into the wheel area, the wheel will last about 14-18 months, removeing the fan will extended life 2-4 years, there will be no heat issues with the fan removed, some models or later production runs will not have this fan
Jan 19, 2010 | Loewe Articos 55 55" Rear Projection...
Loewe articos muffin fan stops..
If Fan stops running Lamp will not Light and TV will not come on!On your Menu you should have in there a listing for Lamp Timer it should tell you how many hrs you have on Lamp and Ballast Board is what turns Lamp on if you need Parts Call Encompass 1-800-638-3328 or UED 1-800-648-6657
Jul 10, 2009 | Loewe Articos 55 55" Rear Projection...
Loewe Articos 55 inch DLP does not turn on
Your problem besides color wheel is the Ballast Board this Board is what turns on Lamp and be sure to CK cooling Fans if fan that cools Lamp is defective Lamp will not light,nor will set turn on!Call Encompass Parts or visit their website they should have listing for parts to your TV 1-800-638-3328 and heres another company you can Call UED 1-800-648-6657 If you need to know anything else let me know.
God Bless and have a Wonderfull Day.
Jan 23, 2009 | Loewe Articos 55 55" Rear Projection...
Loewe articos hd tv rear projection. contrast too shiny
Try lowering Brightness first.Not contrast leave it up middle range.
Dec 26, 2008 | Loewe Articos 55 55" Rear Projection...
55 in loewe articos rear projection
You might have defective Fan if Fan stops running Lamp will not Light also keep in mind Ballast board it what turns lamp on and Fan is what keeps Lamp cool, and most of the time if set is not comming on Lamp is Bad. Call Encompass Parts 1-800-638-3228 or UED 1-800-648-6657 main 3 parts to DLP is Lamp,Ballast board ,Lamp Fan.Id say you have Bad Lamp! God Bless and hve a wonderfull Day.
Nov 02, 2008 | Loewe Articos 55 55" Rear Projection...
Loewe articos 55
had same problem, solved by lamp replacement. back to full glory!
jurgen
Oct 07, 2008 | Loewe Articos 55 55" Rear Projection...
Loewe Articos 55 RP
There is a software patch that increases the cut off temperature you may get this at Loewe Website. Quick fix is reverse one of the fans on the back of the set this gives a through flow of air rather than all fans blowing into the set.
Apr 24, 2008 | Loewe Articos 55 55" Rear Projection...
Image doesn't come on but the green light is on
95% of the time this is caused by the lamp. Inspect the lamp again 9 times out of 10 the element will be shattered sometimes the force of the fail can cause the glass to shatter, the force can also cause futher damage but this is unlikely. Have the lamp replaced check the hours lamp should last around 3,000 more if you switch off with the remote never the side button. Reset lamp counter to zero.
Jan 06, 2008 | Loewe Articos 55 55" Rear Projection...
Will tun on but no picture??
The main problem for this is that your lamp needs replaced. It is an Osram lamp but many manufacturers had these made to slight difference in specs to ensure only they could cash in on the spares.
May 13, 2007 | Loewe Articos 55 55" Rear Projection...
Loewe Articos 55 55" Rear Projection Television Logo
183 people viewed this question
Top Loewe Televison & Video Experts
Jerry Umali
Grantec 2000
Level 1 Expert
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
