Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
REMOTE NOT RESPONDING TO INFARED CENSOR RCA #D52W20B IT WAS BEFOR
I HAVE 2 52' BIG SCREENS THAT ARE THE SAME WITH SAME REMOTES THE ONE TV IN QUESTION IS NOT RESPONDING TO THE REMOTE
    Problem Solver:
  • 61 Answers
Behind your screen is an ir reciver it may came loose it goes to your signal board
Posted on Nov 22, 2008
.I have 60 inch rca guide plus big screen tv control buttons don't work correctly
Replace the batteries.....use the matching process in your manual to make sure the controller and tv are matched up....check the tv settings by using your buttons on the tv...to make sure it hasn't been set to function manually...and not to respond to any remote controls....replace the remote controller....make sure the receiver eye or sound collection area of your tv is not covered by a drape or decoration of some sort...and clear and free of obstacles to communicate with the remote controller.....make sure the tv and cable box are correctly plugged into the electrical receptacle and to each other.....you may have to program your remote control to control your cable box too...instructions in your manual....or call the cable company and they will set your cable box controller to control your tv ......step by step over the phone.....it could be a high number of other things...like your neighbors remote interfering or the hamm radio guy down the street interfering.....but there are a few basic things to check out before calling a tv repair guy to come and get you working.
Good luck and I hope I was some help.
May 01, 2015 | RCA Televison & Video
Need Remote Controler Codes for Toshiba Remote for Toshiba Model TP61H60 a 1998 Big Scrren
Your Toshiba remote should have the necessary codes to control your Toshiba TV unless one is much older than the other.
If your RCA remote is programmable, you can use its "code search" feature to find an applicable code or codes. If a complete search of all codes stored in your RCA remote fails to find a code, you may have to try another programmable remote or simply wait until the replacement Toshiba remote arrives.
Sep 25, 2014 | Televison & Video
Hisense tv model number LCD42v68p is not responding to remote and menu buttons screen comes on with alphabetical letters how do i fix that
Hi, Try puting new batteries in remote. Make sure remote has clear view of TV censor. Remote maybe damaged in side replace with new one. Good luck.
Aug 07, 2014 | Televison & Video
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
RCA TV won't turn on!
On the deflection board there is 3 capacitors cp150 2200uf 16v if puffed up on top it is bad so then replace other 2 capacitors as well 220uf 35v. cp114 cp120
Feb 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv keeps changing the channels on its own
take out the batteries of all the remotes that are able to change the channel and put a piece of duct tape over the infared reciever and if it still does it, it is most likely defective.
thanks,
Nate
Aug 22, 2008 | RCA Universal Remote Control
Power problem on a RCA big screen TV
Even with the tv turned off, the power supply is still active.It's supplying voltages to the microcontroler, that's why each time you press the power button on remote the tv respond by turning on. First check the power cord to be well connected in the power-bar and if it's ok...well the power supply is defective and due to the high risk of electric shock i suggest you to call a technicien.
P.S. I respond here because I don't know why our chat session got disconected.
Feb 01, 2008 | Televison & Video
Having problem with the remote control
have u tried a new remote or universal remote? if the tv doesnt respond to anything you might need a new infared sensor your remote control part number is AH301805 AH302260 is the remote control board for the set hope that helps
Jul 04, 2007 | Toshiba 19HLV87 19 in. LCD HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
