Question about Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range
Frigidaire Electrolux Dual Fuel PLCF489CC -- Interior Frame Bent
While checking on a roast in the oven, my mom slipped and fell -- bracing herself on the left bottom side of the oven door, and burning her hand. The oven door will no longer close, because while the hinges are okay, the interior frame on the lower right side is bent outward slightly, just above the hinge.
We had a repairman come out through our homeowner's insurance policy and he said that he couldn't repair it because it wasn't normal wear-and-tear. He said it could possibly be "banged out," but that it might ruin the integrity of the oven.
Is this the case? We're trying to make the determination if this can be repaired, or if we have to replace the entire range.
Thank you for your advice.
  • laine_n Nov 10, 2008
    Would appreciate getting a second or third opinion, please. I know it's difficult without having a visual of the problem, but perhaps someone has tacked a similar issue?
    The frame is bent/slightly buckled outward just above the hinge of the door. About a 3 inch long area is affected.
    Master:
    Sergeant:
  • 449 Answers
Hi!!
try to find out in the surplus
if there is available
or replace it
Posted on Nov 10, 2008
  • 905 Answers
Its metal so the paint job will crack and yes the integrity or heating may just cause it to warp in the banged back to shape areas, so maybe you can try to get a replacement door for it before you buy another one, (just another option)
    Sergeant:
  • 229 Answers
It is very possible that this could be repaired. I once repaired an oven that had similar damage. The outward bend could be mechanically manipulated so that the door could once again close properly. I would advise unplugging and moving the range to a proper work area so that there will not be any danger of electrocution etc. Be aware however that many electrical devices have components in them that hold electrical charge even when they are not plugged in. Be careful. My opinion many times is that there is no harm in attempting to repair before replace. Good Luck and hope moms better
  • Lance  McKinney
    Lance McKinney Nov 10, 2008
    With a little better understanding of the problem I would suggest trying to straighten ou the bend in the door (remove just the door via the hinges and use a lightweight flat sided hammer to tap the bend back in if this does not resolve the problem simply replace the door, not the whole range and save a ton of money doing so. As long as the repaired or replacement door lines up properly the integrity should be ok. Hope this helps.
  • 1,543 Answers
As findmeifucan stated, we need to know what was all damaged, and also what the full model number is. You can get the oven liner, for example, ( 318089617) but you may need other parts also. The labor would be rather costly, but it looks like that is a rather nice range and might be worth the investment.
    Genius:
  • 1,550 Answers
You need to replace the entire range .
Repair is uncertain as we dont have clear image of what is damaged .
Electrolux dual fuel oven will not heat after self clean
The unit needs to be reset. The temperature had tripped the internal sensor of the unit. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside.
Sep 02, 2012 | Electrolux EW30DS65GS Dual Fuel (Electric...
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I...
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 22, 2011 | Electrolux Ovens
Is it better to use convection roast for turkey
useing convection takes some practice but once figured out you will never use your regular bake feacher again. look on line for convection tips, most conv ovens come with a guide book some come with a video
Dec 25, 2009 | Electrolux Frigidaire Professional Series...
Convection cooking
Convection ovens are great for roasting!
I cooked a 15 lb  stuffed turkey in 2 hours in mine. And it was juicy and fab!
My auto degree set for convection  is 325.
I have a Jenn Air wall oven, so I don't know, it might be different for different brand.
Roast or bird should be in the middle of the oven. THe air has to circulate well to get best results.
I believe rule of thumb is a convection oven takes 1/2 LESS time than conventional.
Hope this helps.
Jan 13, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire 40 inch range model #REG46NW-2
OPEN THE DOOR COMPLETELY. IF IT GOES BEYOND HORIZONTAL, THE HINGES ARE BENT FROM EXCESS DOWNWARD FORCE. THEY WILL HAVE TO BE REPLACED.
CHECK THE DOOR HINGE SPRINGS TO MAKE SURE ONE OF THEM ISN'T BROKEN. IF YOU FIND ONE BROKEN, REPLACE IT.
Mar 31, 2008 | Frigidaire PLCF489AC Dual Fuel (Electric...
Oven door shot open
wine fumes ignited i would not recommend putting alchol in a closed space with 450 degrees of heat
Jan 14, 2008 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range Logo
111 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
