Question about Samsung HCL4715W 47" Rear Projection Television
Blury lines in the picture / no picture / intermitent no control
This problem is just really upseting as its a relativley new tv. The picture gets some lines in it, all three colors and in a diamond pattern that is irratic. if i jossle the tv around or bang on the circuit board the picture comes back for a whyle. the problem reoccures unfortanatly. does any one have a better fix than to keep beating up the tv set.
  • Bill Geisler Nov 05, 2006
    I looked at the board pretty close. The only spot I seen that was obvious was the loose connection where the attenna housing mounts to the main PCP. it appearedto be just the mounting that came loose. there are still three solid to the board. I did not think this had any bearing on the problem. I called a repair guy trying to get info and he mentioned a depression board? does this sound like a viable solution? I unpluged all cables and plugs to make sure there were good connections. I think i may take the boards out again and re inspect. Can you pinpoint me to the correct circuit board to look for trouble. there are three. main power, Depression? and the main PCP if thats correct. I have now been getting blips of color lines red blue green that turn into the full blur cross diamond pattern. the banging of the board still corrects the problem temporaly.
  • Bill Geisler Nov 27, 2006
    Hello I have new news regarding the problem with my TV. The problem is fixed. I took the advice I recieved about hte circuit board and looked over it very closely. I found that some gel had leaked onto the circuit board and coroded two wired on the board. once I cleaned the mess off the board and put it all back together. The TV works fine now. I believe that some of the cooling gel around the green tube leaked out causing the problem. I hope that this will help someone else.
    Sergeant:
  • 337 Answers
Is great you have already found the place to hit and get the picture back,is a loose conectiont that need resoldering before it gets worst or damages something,be ateentive were you hit and flip the crcuit board,the broken solder joints should be easy to spot. If you are not too familiar with tv service seek the help of a servicer and tell them what you do to make it work,the repair should not be xpensive since you already diagnose the problem.Good luck
Posted on Nov 05, 2006
  • Omar Urrutia
    Omar Urrutia Nov 05, 2006
    Your rating response is also important.
  • Omar Urrutia
    Omar Urrutia Nov 21, 2006
    Even if only one of the mounts is loose can give you problems,it could be the one that conects the ground to the other three,it should be resoldered regarless,resolder anything that does not look right.You already know you have a loose conection.
I get blury pictures
Possible that the CCD is a suspect. Try and allow the camera to be switched on for a long time, keep free from moisture or near a lamp to dry.
If not best is to take a referral for consensus without tampering without proper jig, spares and tools.
Dec 11, 2012 | Canon PowerShot A470 Digital Camera
The picture is blury
The convergence is dead,need a convergece kit,U know how to solder right?Tries these websites.for the kit.Tv Repair World.com, Shopjimmy.com,Ebay.com or Partstore.com.
Sep 08, 2009 | Sony KP-53HS30 53" Rear Projection...
Red and green curved lines when the screen is dark
Your convergence board is going out. this will have to be replaced. i would take a look at the main logic board as well. it could have minor point breakage.
Feb 09, 2009 | Sony KP-57HW40 57" Rear Projection...
TV, RCA MOD # F19424, CTC 203U5, Picture blury
Focus and Screen. The focus control may help, just like focusing a set of binoculars or an old camera. Watch the picture on the TV, using a mirror can help and make an adjustment until the picture is as clear as you can get it. If it still is not clear it may mean that your picture tube is weak.
If you can avoid it, don't touch the Screen control. If you have, let me know and I can advise you on the proper way to adjust it.
Oct 09, 2008 | RCA Televison & Video
Mitsubishi big screen blury
In all probability the picture is fuzzy too, its just harder to notice. This can be as simple as an adjustment in the back of the set. Carefully remove the back and look for the flyback transformer (part with large red wire coming out of the top). The should be 1 or 2 controls on it. One should be marked focus. Adjust that to get sharper focus.
Let me kow if that fails to resolve the problem.
Thanks,
Dan
Sep 30, 2008 | Mitsubishi WS-55807 TV
Big screen on bad red lineand blury
Good DAy, mitas;
It sounds that the TV is having a Convergence Circuit problem or you may CRT Coolant (fluid) on the PCB's. Good Luck, big IRISH........ PS Call for help, by calling a Factory Service Center....get an estimate!!
Aug 31, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Picture blury
Its behind the speaker grille up front , remove the grille and then a small access panel and you will see the focus control with 1 button for each CRT 3 buttons in all.
Jun 16, 2008 | Samsung PCL545R 54" Rear Projection...
Jvc
I have the same problem on my tv - the colors are seperated - the picture is blury and in converge mode the colors will not line up.
Need to know if I need to go and buy a new flat screen tv.
Any advise is appreciated. Thanks
May 25, 2008 | JVC AV-56WP74 56" Rear Projection...
Rca f25432
picture blury problem is due to 1 focus wire loose or disconnected due to long life of connection.this wire is in crt base. 2 focus control mistunned. 3 low voltage on crt electodes. 4 if tv is old then crt is getting weak. 5 crt base or connector loose hope this helps. good luck
Sep 29, 2007 | RCA F25432 25" TV
Samsung HCL4715W 47" Rear Projection Television Logo
27 people viewed this question
Jerry Greenberg
Jerry Greenberg
