Question about Denon Televison & Video
Hello. I just bought two DN-V210/DN-V310 players. I use a sync-unit to syncronise the dvd's. I have problems with the sound, I use analogue conections, stereo, 48khz/16bit. The dvd's play but sertain sounds are not heard at all. I played around with the souns settings, tried diffferent options but the problem wasn't solved. \ What do you recomend? Many thanks my email is loukia.alavanou@network.rca.ac.uk
  • 3 Answers
SOURCE: Problem playing DVD's
My DVD player once fell off a shelf and then stopped working. It would show the CyberHome background on the TV but did not play anything. I took all the screws off the outside, removed the metal shell, then there was the DVD tray with a metal covering (4 small screws). I could see below the tray was a connection that came undone rather easily. It controlled the spin motor I believe. I just reconnected it and it worked. I heard clicking noises because the lens/mirror apparatus was moving back and forth but the disk wasn't spinning. Hope this helps. Alex
Posted on Feb 27, 2007
SOURCE: Recorded DVD wont play on any other DVD Player
I lost my manual. Can you describe how to finalize it? I can't finad any buttons to press that say finalize on them.
Posted on Jun 15, 2008
marked
  • 6487 Answers
SOURCE: HELP
To quickly and easily unlock your dvd player ,you will need to use a device like dvd exploder since you can not find the specific code for your it or also go to one of the web site that offer dvd unlocking..
Hope that helps.........
Posted on Jul 26, 2008
SOURCE: How to reset my Denon DN-V210 DVD Player to factory default?
Hi Jason,
I have just bought this unit and have been using the menu recently. The only ways i can see to do it would be to either, (as you say) plug it into a HDTV, or navigate the menu blind and hope for the best.
If you press SETUP on your remote once to get to the menu setup screen and then push the RIGHT navigation button 3 times this should take you to the system setup screen. Then push the DOWN navigation button 4 times and then push ENTER. At this point it asks you for a 4 digit password to reset the unit which is a factory preset, 5555, so type that in. This should then reset the DVD player to factory settings.
Hope it helps,
Nick
Posted on Nov 19, 2008
SOURCE: DN-V310 Audio no Picture
Don´t you put the progresive scan by mistake
Posted on Jul 08, 2009
We purchased a Denon v310 to play multi format dvd's and the message we get is wrong region, how do I unlock?
  1. Turn the unit on
  2. Press the OPEN/CLOSE button
  3. Press CLEAR, 1, 4, 7, 0, CLEAR - "TEST MODE" will appear on the display.
  4. Press UP; "00 XX" (XX is a numerical value) will appear on the display. The first two digits are incremented by one, every time you press UP
  5. Press the UP key until you see "12 XX" (default is 24) on the display
  6. Press 2, 3, ENTER
  7. Press UP key again and you will see "13 XX" (default is 23). If it does not say "23", press 2, 3 on the remote and then the ENTER button
  8. Press the UP key again and you will see "14 XX" (default is 01).
  9. Press 0, 0, ENTER
  10. Press RETURN
  11. Press CLEAR twice
  12. Press RETURN ("END" should appear on the display)
  13. Press OPEN/CLOSE
May 10, 2011 | Denon DN-V310 DVD Player
Unit will only read certain dvds
you can try cleaning player by opening up unit and very gently try cleaning 'eye' on player with a Qtip and rubbing alcohol
some players have issues playing some DVD formats though so if this unit never played certain DVDs that is issue that cant be fixed
good luck!!
Mar 25, 2011 | Denon DN-V210 Player
How to change the region code?
The player will play all region codes without tampering !
Feb 08, 2010 | Denon DN-V210 Player
Jul 08, 2009 | Denon DN-V310 DVD Player
Mistracking on dvd player
Hello!
It turns out there is a problem using hdmi cables with integrated amplifiers Denon dvd players (the 1940 series) - the hdmi cable processes the visual signal before the audio signal. Therefore there is what appears to be a lip syncing problem because there is a short 'time delay' between the visual and audio signals. I would advise anyone to simply use an AV reciever as they incorporate time delay technology so the visual and audio signals are in perfect sync. Luckily, Richer Sounds, where I bought the intergrated amp gave me a full refund, no quibbles or hassle. I would like to add I am unsure if the problem lies with just the Denon 1940 hdmi dvd players and intergrated amps or ALL hdmi players. Also, I was trying to achieve a simple 2 speaker set up with the amp.
The forum on What Hi-Fi document this problem with much better clarity and technical explanation that my understanding of the problem. However, the lesson learned is, if you want any speaker set up with your dvd player, use a dedicated AV reciever.
Best Regards, Graeme Young.
May 17, 2009 | Denon DVD-1940CI DVD Player
Denon DN-V210 won't play DVD's burnt with Final Cut Pro
Then the format can't be read by the MAC, what reason this is I have no idea.
Apr 11, 2017 | Denon DN-V210 Player
Hi Jason,
Hope it helps,
Nick
Nov 14, 2008 | Denon DN-V210 Player
Getting a Disc Error when trying to play a Chinese DVD
For starters, the Chinese have a totally different set of coding than most anyone else. So you would most likely actually have to buy a dvd player out of China to read it. Otherwise, get teh right codec's for your computer to play it on a dvd rom drive for the computer. Im sorry that this may not be what you are looking for, but ive learned from buying a lot of foreign movies, that you most often have to buy the playing equipment also from the country to play it.
Oct 28, 2008 | Denon DN-V310 DVD Player
Region problem
To set the DNV-310/210 to Region 0 (Region Free), on the IR remote press:
OPEN/CLOSE
0
0 - this is where you input the region code.
Nov 19, 2007 | Denon DN-V300 Advance Progressive Scan DVD...
Televison & Video Logo
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
