It will not stay on...it comes on then turns rite off
I just cut the protect3 jumper (J101) on the inverter board on the middle left hand side. Just make sure nothing is overheating and it might work for you. Let me know if it helped you.
I am sorry... I do not understand what a "protect3 jumper (J101)" is -- I am not smart about any of this.
I am sorry... I don't know how to use this web site yet. Apologize to all for confusion I caused.
Apparently, one of the inverting transformers is pulling a little more current than normal and is triggering the protect. So just cut the small jumper wire as described to block the turn off signal and that should take care of the problem at least for a while.
Need more info to assist when you say comes on and goes right out are you refering to the power indicator light only or does the Screen light up briefly then go out? Let me know and I will assist you with the issue.
SOURCE: my Sylvania TV LC320Sl1 will
lori2scott...did you ever solve your problem? Mine is now doing he same thing and I dont know what to do. Thx pwest17
SOURCE: In Dec 2010 I received
You can find most User manuals on line for a price. But if you look long enough, you can sometimes find one for free.
SOURCE: Sylvania Model # LC320SL1. What is the 3 - digit
Try this link it contains remote codes and instructions.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
SOURCE: how come the initial setup
the setup button is partially or completely stuck on on the front/side/top panel.
SOURCE: My sylvania lc320sl1 won't turn
I had this exact problem. I went to the Sylvania website and found a firmware upgrade for my TV. The Sylvania site provides detailed instructions with illustrations. This worked for me and fixed the problem.
Please follow the instructions exactly and if you are not tech savvy, ask a knowledgeable friend to help. You should not attempt to upgrade firmware unless you have confidence in your ability to do so. You *could* end up with a completely dead TV if you mess it up.
