posted by rgdarby on Nov 04, 2006
I have a Gateway 600XL which has a Pentium III 600MHz Slot 1 chip. Can I replace it with a 1 GHz Slot 1 chip?
Best Solution
posted on Mar 30, 2007
According to this review, you can upgrade as far as a 2 GHz P4-M at least;
http://www.pcmag.com/article2/0,1895,669...
Other than that, i have been unable to find the details of your motherboard - if you can post the make and model (should be printed on it somewhere) then I would hope to find a more complete list of compatible and incompatible processors.
Gateway themselves no longer offer online info or support for this model, but the motherboard details should enable me to find out what you need to know.
Waiting for your post :)
Comment by Noggin, posted on Mar 30, 2007
My bad - thanks for the info
Comment by Noggin, posted on Apr 03, 2007
I've had reponses from older threads than this, so is usually still worth it (not in this case)
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
It seems that Noggin is confusing a Gateway LAPTOP computer with an old Pentium III Slot 1 CPU... The old Gateway P-III motherboard will NOT support the faster CPU; the 1 GHz P-III CPU requires a LOWER voltage than the motherboard can provide...
Comment by printerhater, posted on Mar 30, 2007
Happens to the best of us, Noggin... keep punching, you've helped a lot of people with excellent advice, and this is an old thread anyway...
Suggest a new solution for this problem
Post a New problem for Gateway Pentium III , 600 MHz
Email this problem
Email this problem
Can you Help with these Processors problems?
Repair Service
Find Processor Repairman Near You:
