N0 display on my Pc, works intermitantly. Checked Monitor ok, also linked hard drive to another pc, that is also ok, I have changed the cmos battery, please can you advise what else I can check. The problem occured after I let my son chat to a friend on Msn, although I have Norton Installed. Thanks in anticipation
    President:
  • 624 Answers
It is probably the video card, if you have checked the monitor, that is about all that would cause this.
How did you check the monitor? Did you connect it to another PC and it worked with not problems? If so, change the video card and you will have your display back again. Your son on MSN is probably not connected to the problem. Everything works just perfect, right up until it fails!!! And everything will fail at some time or another, your son had the bad luck of being the one on the computer last.
Let me know if I can be of more help,
Dave
Posted on Nov 10, 2008
Changed cpu on packard bell imedia d3318, still getting no signal on monitor and no beeps. When I remove the cpu and power on, there are no beeps
Have you check with different RAM, Did you try to reset BIOS by removing the CMOS battery and shorting CMOS jumper? Your Processor may be ok but you are plying with it. When there use to be no display then first thing you should doubt with the CMOS battery and the RAM and Motherboard, rather then CPU, CPU hardly gives problem.
Aug 14, 2012 | HEWLETT-PACKARD Computers & Internet
My hard drive clicks and the moniter turns off
Hi, you can isolate that problem to see what is the defective part;
1. Remove the hard disk connection from the board and its power then re-start the PC.
2. If the PC powers and initializes, then you can prove that the defective is the hard drive. If the same problem that it shuts down then. the next target is the power supply. If you change the power supply and it turns out success, then we have solved the problem, if not, next thing is,
3. Turn off PC, remove the battery/clear cmos, the memory and the processor for 20 minutes.
4, After 20 min re-install the battery, memory and processor. Without the hard drive when starting, lets see if it will boot without the O/S.
others, when you say the monitor turns off, does the CPU still working or not? Isolate also the monitor by powering it on and not attaching the communication cable to video port, lets see it the monitor itsel display by its internal video logo to be sure it is okay.
Jun 22, 2011 | Computers & Internet
All the components are working properly but i am not getting anyh display on my monitor i replaced every thing and checked my monitor is working ram is working cpu fan is working power supply is ok smps is...
1- evolve the battery.
2- install it again but upside down.
3- turn on the PC.
4- wait 15 seconds.
5- turn the PC off.
6- install the battery correctly and enjoy. please rate.
Jan 17, 2011 | Mercury P4VM800M7 Motherboard
My display do not tern on
If you unplug the signal cable from the mainboard, does the monitor display the message "no signal" or any similar? If yes, then try to unplug connected components to the mainboard (hard drive, optical unit) and see if pc starts. If no change, unplug power cord and remove the CMOS battery for about 20 seconds then try again.
Sep 02, 2010 | Computers & Internet
Monitor blinking
Have you tried windows reinstalling? if not, please try as soon as possible.
Apr 18, 2009 | Computers & Internet
Monitor power indicator blinks but doesn t show desktop.
you have to put the proper secreen resolution. you do these
1. you checked it with another pc when it shows the screen then change the display properties screen resolution as minimum lke 600X800.
2. you also change the screen refresh rate to 60 Hz to solve this problem.
ok
thanks
Nov 13, 2008 | Proview Computers & Internet
No display
hi ,
this can be problem with CMOS ,reset CMOS by jumper or disconnecting CMOS battery .after this still problem with display please disconnect Processor from motherboard get cpu on without processor for 2 min .& after that cut off power assambled it as it is with processor & cheak it out
Display will come
If this information is useful for you please rate me ............
Jun 10, 2008 | Gateway GT5028 PC Desktop
No display on LCD monitor
hi ,
Display will come
Jun 09, 2008 | Gateway GT5028 PC Desktop
Computers & Internet Logo
David Payne
David Payne
