Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore W/D #110.88762793 keeps filling w/ timer in any position
If you push in timer knob it stops filling. Pull out timer knob and it keeps filling in any position. I blew thru the water level pressure switch hose to make sure the hose is not clogged.
  • 5,911 Answers
If the washer does not shut off when filling, the pressure switch is usually the culprit. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
In many cases, the only problem is the air hose comes loose from the switch, or is cracked or punctured somewhere. If the air hose is intact, and the electrical connections are good (no broken, loose, or corroded wires), then I would recommend replacing the switch. The part is available at searspartsdirect.com. Just go to the website and type in the model number you have provided and go to the "Washer/Dryer Control Panel" heading for itme number 13 (part #3952465). I hope this helps you. Please let me know if you require additional assistance.
Posted on Nov 11, 2008
Model: 110.29822800 Cycle Control knob seems loose. When turn knob clockwise and pull knob, it seems like out of position. For example, I set at Normal, rinse and pull knob. It rinse a minute or two and...
Could be one of two things. The knob or the timer. Both knobs and the timer through sears parts direct are under 100 probably with shipping. If the knob that you pull out and push in does not feel sloppy when you turn it then i would guess timer is faulty.
Feb 27, 2011 | Kenmore 24032\24036 Top Load Washer
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    The knob on my kenmore elite won't move the timer.
    The knob itself turns the switch on . The skirt move the timer position. Try turning the skirt. You probably have a broken knob. On these the knob is held in place with a plastic rod inserted into it all the way. This spreads the tip and retains the knob. To get the knob off to yank out the skirt for a look see you need to pull that rod out a tad to release the knob. 88be11a.jpgThat shaft has a rounded end on it that spreads out and locks the knob on. Clever ain't it? These timers are cheaply made, if you cannot find fault with the knob or the skirt then you is gonna need a timer.
    Jun 05, 2010 | Kenmore Washing Machines
    Kenmore 90 series washer. As the tub tries to
    It sounds like you have a bad timer. If you change the position of the timer and it does not change what is going on the the timer has to be bad. However I am not certain what you mean by the agitator turns all the time. Is it agitating while spinning and draining?
    Apr 15, 2010 | Kenmore Washing Machines
    I have a Kenmore gas dryer model 97591220. wont
    Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
    Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
    Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
    Push the timer back into position on the console and secure the console rear panel in place.
    Apr 14, 2010 | Dryers
    My kenmore 800 washer stops mid fill. i push in
    sounds like the timer has a bad spot in it probaby a factory thin spot in the dial
    it's where the coil or filiment has a gap even a micro gap or wear spot can cause this
    Jul 29, 2009 | Washing Machines
    Kenmore dryer keeps on going and going
    The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
    Feb 12, 2009 | Kenmore 64902 Electric Dryer
    HELP ME WITH MY PROBLEM
    if water stops when knob pushed in raise console (probably screws under each end cap just pull caps toward you to remove )remove screws lift console ck small hose going to water level switch to be sure it is pushed on ..if water will only shut off when faucet turned off replace fill valve
    Dec 12, 2008 | Kenmore 22422 Top Load Washer
    LTE6234 Whirlpool Twin Thin Timer Broken?
    Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
    Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
    Kenmore 98702 Stacked Washer/Dryer Logo
    209 people viewed this question
    Sal De
    fordexpert
    Robert Rankin
