2001 Nissan Xterra Logo
Posted on Nov 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil capacity for my 01 nissan x terra
I have a 2001 nissan x terra se 4x4 v6 and im wondering how much oil do i need for an oil change, also i was going to put 5w30 in (i live in canadas far north) for winter. any thoughts?
Anonymous
Level 2:
Sergeant:
  • Expert 229 Answers
  • Posted on Nov 10, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
229
Questions
Helped
93763
Points
621
The 3.3liter motor requires 3.8 quarts of oil. 5w30 should be a good oil for the extreme conditions required in your climate. Most new car manufacturers now recommend 5w30w so that says volumes - hope this helps!
How do I remove oil pan on a 2001 gmc Sonoma pick up truck to replace gasket
1993 GMC SONOMA 2.6 CYL V6 NOT 4x4 OIL PAN ...
? 2:31
https://www.youtube.com/watch?v=1KsRTlnW7Cg
Sep 27, 2011 - Uploaded by JohnSmiths8379858
trying to reomove the oil pan to this truck has been sitting for about 6 ... 1993 GMC SONOMA 2.6 CYL V6 NOT 4x4 OIL PAN REMOVAL "HELP!
Oil Pan Gasket: How to Change Oil Pan Gasket for 2001 ...
www.2carpros.com/questions/2001-gmc-sonoma-oil-pan-gasket
Mar 18, 2011 - How to change oil pan gasket for 2001 sonoma, can i get away with just raising the engine two inches to ... 2001 GMC Sonoma • 4 cylinder 2WD Automatic • 150,000 miles ... You need to remove the engine to get the sump off.
I have water in my 2001 s10 4.3 v6 4x4 I was wondering if it could because my oil coolant went out or what can it be
If you are saying that you have water in the oil, it is because the engine overheated and the head gasket blew out.
How much oil do i use in my 2001 holden frontera se v6 3.2lt with a filter?
start with 3 liters oil. Start engine at least for two minutes fill up oil filter. Turn off engine and check oil level. Keep adding with engine off until full reading on dip stick guage. keep record of oil added for future reference. Make sure oil API is at least SL
2helpful
2answers
How much fluid do i need for my 2001 potiac grand am se 4 cylinder
It has a capacity of 5 quarts of SAE 5W30 oil with filter change. The cooling system capacity is 2 3/4 gallon of a 50/50 mix of antifreeze and distilled water. The 40T40E transmission/torque converter holds a total capacity of 12.9 quarts or 6.9 quarts to just drain the pan and replace the fluid.
3helpful
Oil capacity for 1989 toyota v6 pickup
Capacity with filter change for V6 4x4 should be 4.8 qts. V6 2x4 should be 4.5 qts.
7helpful
2answers
How many O2 sensors are on the '01 Grand Am SE V6
YOU HAVE 2 OXYGEN SENSORS.1 ABOVE THE EXHAUST MANIFOLD WHICH IS THE CRITICAL ONE AND YOU 1 OXYGEN SENSOR AFTER THE CATALYTIC CONVERTER.
1helpful
3answers
What's the typical car life for a 01 nissan sentra?
ITS just run in you silly person as the normal engine (the heart of the car) will do about 200,000 miles and still go strong ...But you dont have to drive like a mad man just look after it and it will serve you well ..
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
