SOURCE: how to reformat my compaq presario cq50 without using a disk
It will restore everything back to factory settings like it just came out of the box. Try the F11 like i suggested.
SOURCE: how to restore to factory settings presario cq50
2 possible solutions to this
1. Use the roll back function of your operating system to roll back to the last back up.
2. Insert your restore disk or Windows disk and do a format/clean install.
If you have a restore disc it will have prompts to "restore" your system and give you a warning about losing data-save off what you want BEFORE doing this restore
If you have standard windows disk you may want to use the format utility in windows first to clean the drive and do a fresh install.
Once installed don't forget to download updates and back up and then reload your other software.
have fun this will take several hours depeneding on the amount of stuff you have to reload and patch up.
SOURCE: laptop comes on and then goes off
plug in adaptor if charge light does not come on its adaptor if it does you have a hardware problem
SOURCE: Compaq Presario CQ50 SD card reader not working
The HP website is the best place to get the driver, try to reinstall the driver, test the card reader again, if not work check this: the SD card in other reader, the correct connection of the SD card, look inside the reader for dirt or small objects.
SOURCE: Need CD to Format my HP COMPAQ Presario CQ50-21OUS
hi sir..There's a formatting option available during the install. Just boot from the Vista CD and select the partition where the old installation is. Windows will do the formatting for you.
if you don't have vista you can download it from the following site and then boot your system
http://www.softpedia.com/get/Others/Signatures-Updates/Windows-Vista-Service-Pack-2.shtml
