Question about Kenwood XD-A75 CD Shelf System
Turns ON but switches OFF immediately
I got this XD-A75 system for the last 4 years and it's been great until last week, when I hit the power button, it turned ON and got immediately switched OFF. And this happened everytime I tried to turn it ON. The last time I used it for is to listen to some music from a CD. Also, I frequently use it for TV while watching some movies. Is this something I can do it myself or do I have to take it to a repair shop. Thanks
  • terimom Dec 28, 2007
    yep only the thing says protect ! go figure huh ? it will not come on .
That happened to me about a year ago, and i think it happened after a storm. i must have sat there and turned it on at least 50x. so finally i just left it unpluged for about an like a day. pluged it back in and it worked.
Posted on Jun 29, 2007
I have kenwood XD-A75 stereo,and i have not been able to remove the demo mode after i try to cancle it it just comes back after i turn the power on, i read the manual but nothing. is there another step i...
When the AC cord is first plugged into the unit, the unit will go into demo mode. To cancel demonstration mode press the Ex.Bass/Demo button. This button is on the front of the receiver, left side towards the top. The demo mode will be cancelled and the receiver will be in low power consumption mode. It may appear that the unit is off because the display will disappear but the radio is in fact on. When the radio is on you can also adjust the bass with the Ex.Bass/Demo button as well.
Mar 24, 2011 | Kenwood XD-A75 CD Shelf System
My acer netbook was working fine with connecting to the internet, until last week - no stating no connectivity. Tried to reset system, but still not working - also very slow
You might've hit the button that turns off wifi. Check to see if you did that.
Also for slowness. Download malwarebytes (google it, its free) and ccleaner. Run both of those and cleanup your system. That should make a difference.
Mar 01, 2011 | Acer Aspire One Netbook
Ps3 wont eject just turns itself off
Try booting the system while holding the power on button. Hold the button and keep it held until it turns off. After the system shuts off, try turning it on normally. Let me know if this helps.
Sep 15, 2009 | Sony Playstation 3 (PS3) Console
95 GMC ignition system doesn't power
Sounds like an alternator problem. Pull it of the truck and take it to a parts store and have them test it for u. Its free at most parts stores. while your at it replace all power cabels and grounds the trucks old new cabels and connections cant hurt. Side post batteries have a bad habit of ratiling lose connections. hope this helps and good luck.
Aug 15, 2009 | 1995 GMC Sierra
Iginition system does not get power
did you check all the fusable links sometimes they dont break all the way maybee check all the grounds on the truck there is one on the back of the head and should be a comp. ground and of course the engine ground from bat. sometimes you have to losen them and retighten to establish a new clean ground
Zodiac LM3 24S won't turn ON
Two Things come to mind, the board, or it could be that the life of the cell has expired.
The Pool Tech
Jul 13, 2009 | Zodiac Duo Clear System Chlorine...
Repair manual
Requires repair manual is available HERE for small fee.
Jun 19, 2009 | Kenwood XD-A75 CD Shelf System
Leapster 2 Doesn't Recognize Stylus
Hold the hint button (question mark) when turning on the device. When the device turns on, do the stylus calibration and touch each of the crosshairs that shows up. After you are finished restart the leapster and you should be fine.
Jan 03, 2009 | LeapFrog Leapster Electronic Book:...
Turning on problem with Panasonic Viva PT-43LC14
Sounds as you have a bad ballest. The ballest is the power supply that turns your lamp on. You can check your lamp by removing it and it should be clear and no broken pieces of glass. With the lamp removed install the cover and turn it on you should hear no noise and when the power light turns red you should see a LAMP red led blink every 5 seconds. If no noise then the lamp is bad. If you do hear noise you have a bad ballist. Hope this helps. Frank
Sep 05, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Monitor does not work
sounds like a slightly damaged power supply. try powering up with an equivalent supply. if only an ac wall cord is plugged in for power, then internal supply is at fault
May 28, 2007 | Acer AL707 17" LCD Monitor
Kenwood XD-A75 CD Shelf System Logo
141 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
