Question about Sanyo Televison & Video
How can you reset a model ds19390 Sanyo tv back to factory settings without original remote? It is an older analog set.
    Brigadier General:
  • 6,966 Answers
Hi again,
Please see your latest post.
Just a start, do postback how things turned up orshould you need additional information. Good luck and Thank you forusing FixYa.
Additionally,pls be informed that you would be lowering my ranking/rating if yougive me a rating if less than a FixYa. Doing so would prevent my beingable to provide further assistance.
Posted on Nov 18, 2008
Can i reset master password without remote
No. You should have its remote control to do a master reset.
To do a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Aug 17, 2014 | Televison & Video
I HAVE 52" RCA TELEVISION.MY GRANDSONS WERE WATCHING IT USING REMOTE CONTROL.THEY DID SOMETHING;WHICH HAS CAUSED THE SCREEN TO SHRINK.PICTURE NOW HAS APPROX. 4" TO 6" ON ALL...
Can you please give us the exact model of this TV set so we can help you better..by the way did you try resetting the settings of your TV using the remote I believe there's an option there to reset the settings of the TV set....
Oct 21, 2008 | RCA Televison & Video
How to set tv back to factory settings with remote?
Hold the up arrow on the remote while holding it in push the power button on the TV. The tv will reset to original new out of box condition.
Mar 20, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv/video switch won't switch
The model indicated is a older Toshiba rear projection(if another brand/model let me know)
You should be able to select the rear inputs either via the remote (original one) or with the input (video) button on the set.
If in the menu they are grayed out--it means they have been locked out.
Failing that a serious problem exists in the set's microprocessor.
Hint: if you have not tried it UNPLUG THE SET FOR A WHILE TO SEE IF WHEN YOU PLUG IT BACK IT WILL RESET and restore the inputs.
Mar 23, 2012 | Toshiba 42H81 42" Rear Projection...
Mitsubishi hd1080 locked tv will not go on can i reset without a remote
A reset is only possible with an original remote----reset will not cure set not coming on---a model number would tell me more.
Feb 19, 2012 | Mitsubishi Televison & Video
Forgot password for parent control
If you have the original mitsubishi remote and confirm actual model number I can tell you how to do a hard reset of the Tv which is done with the remote.
This will clear and restore all settings in the set to factory default.
sj
Oct 16, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Need tv code, tv is locked
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
5
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Also note that forgotten the passcode of your Mitsubishi TV. You can make it alive without knowing the passcode. Please follow
V_Chip lock bypassing prodedure is as follows
You can view your locked TV, cancel the lock, or enter the V_chip lock menus.
This is done by pressing the number "9" and "QV" buttons on the remote TV control at the same time, when your passcode is requested. This process temporarily unlocks the TV.
When entering the V_Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
I hope this will help to solve the problem...
Aug 20, 2011 | Mitsubishi VS-60703 60" Rear Projection...
How to take the tv back to original factory settings
Unplug,replug the tv back about an hours later.All the tv settings,will return back to the tv original factory settings.
Jun 10, 2011 | Sony KDS-55A2020 55" Television
Image too big
You have two possibilities; either buy the original remote or look up the code for 'universal' remote for that set here:
Remotes
If you can't find the code set for the remote & TV you have, look for a code set for one of the following brand names:
Funai, Symphonic, Sylvania, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, Philips and Misakai
These are all made and marketed by Funai.
Nov 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Remote Control for Magnavox Big Screen TV (PTV 705-AH01)
sgtdar, list the model & chassis number (located on back of tv), if set is old the universals won`t work because as more newer sets come out they delete the older ones because the chip in the remote will only hold so many codes, BMW Rider
Dec 12, 2007 | Televison & Video
Televison & Video Logo
257 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
