Question about Rockford Fosgate Punch 301M Car Audio Amplifier
Rockford fodgat punc 301m remote wont work
Amp powers fine but te remote will not work could you walk me troug wat to do
    Problem Solver:
Try running a target switch. most likely your soulderin came loose inside the amplifier
Posted on Nov 11, 2008
I need to repair my amplifier ..but the tecnition asks me to get the schematics of this amp due to that here in BSAS..ARGENTINA THERE IS NO INFO CONCERNED TO THIS ITEM..thereso...having this info we can...
I have few schematics of Rockford Fosgate units, let me know model number of amplifier to see if its schematics exist in my stock or not.
In case schematics does not exist in my stock, you need to contact Rockford Fosgate for required schematics.
Following schematics exist in my stock:
G250A2
G800A2 Punch 801S PC4333
TEBD10001
1001X
100X2
301M PC 4309H
551S PC4340A H500A2
600A5 PC1986E
601X
MOS 650SCH
PC1000SCH
Power 300SCH
Punch 2001X
Punch 500M
RF2000SCH
Thanks.
Nov 24, 2010 | Rockford Fosgate Car Audio & Video
What do i do
make sure all you wiring is in the right place if they are then you amp have a prob
Apr 15, 2009 | Rockford Fosgate Punch 301M Car Audio...
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Dec 25, 2008 | Rockford Fosgate Punch 301M Car Audio...
Fuse location on a punch 301m
The older Rockford amps required external fuses. There were no on-board fuses.
Nov 24, 2008 | Rockford Fosgate Punch 301M Car Audio...
Amp not turning on
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If neither is too low, the power supply in the amp is probably blown.
Nov 10, 2008 | Rockford Fosgate Punch 301M Car Audio...
Amp turns on but doesnt power my subs
well ill need 2 know wat knobs are all on the front of your amp
Nov 07, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate Power T20001bd goes into protect upon power up.
In most of Rockford's amps, the low voltage detection is connected to the remote input. If the remote voltage is too low and they use the same circuit on this amp, it could trigger the protection circuit.
Disconnect the head unit's remote from the amp. Use a fuse holder with a 3 amp fuse to jump between the B+ connection and the remote terminal of the amp. If the amp powers up, the head unit's remote output may be defective. If it blows the fuse, the remote input or part of the power supply is damaged. Do not try it with an unfused jumper.
Oct 21, 2007 | Rockford Fosgate T20001 bd Car Audio...
No power
hi, some car amps need a high current remote supply to turn on. first make sure that you are using the proper gauge b+ and gnd cable for this particular rockford amp. then try switching the remtote turn on to this amp thru a simple Relay.(use the remote supply from your headunit as a trigger for the relay). do these connections without connecting any spks or rca line inputs. once amp is switching on then connect all other cables. OR lastly check the main fuse on the RF amp?? cheers
Jul 22, 2007 | Rockford Fosgate Punch P325.2 2-Channel...
ROCKFORD FOSGATE Punch 301M Amplifier Problems!!!!!!!!!
Check the Inline Fuse -=Usually located Close to the battery in the engine copartment=- and also check the fuse in the AMP. Without knowing and seeing all of the details i would say to try to bypass the capicator, I know that i always unhooked my inline before jumping the car but i know it happens. Hopefully it will be just that a fuse or the capicator but if some sort of surge resulted from multiple failures get the amp bench tested at A car audio shop. Just some thoughts.
Feb 21, 2007 | Rockford Fosgate Punch 301M Car Audio...
Rockford Fosgate Punch 301M Car Audio Amplifier Logo
99 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
