Question about Onkyo HTR500 Receiver
Onkyo tx-vs515pro won't turn on
I have two of these receivers and I still really like them. Unfortunately, one of them won't turn on. I have disassembled the receiver and tested all fuses. They were all good. The two little orange lights on the front panel of the receiver both light up but when I push the standby button, absolutely nothing happens. I have tried using the remote to engage the receiver to no avail.
It seems there are many different ways on the internet to "reset" a receiver- but none for the TX-SV515pro. Does anyone know if there is a way to "reset" my receiver? Perhaps the standby button is shot? Is there some way to test this?
I most likely won't bring this to a repair shop as reputable shops are impossible to find in my area.
Thanks!
  • capnkalvin Mar 13, 2009
    When I turn my 515 Pro on the power light comes on and the relay clicks but there is no display and there is no power to the outlets on the back of the receiver. I have checked the fuses and am at a loss how to proceed. The local repair shop is real busy and won't be able to check it out for weeks. ANY help????????????? Regards kevin(;
  • harley5571 Apr 21, 2009
    tried that test never appeared
Doubt that reset will fix your problem---but here it is if you want to try:
hold down the cd button and press the power button [at the same time]
test will [should] appear on screen for about 5 seconds--you need to unplug the set during this 5 second period. this resets the cpu chip.
hope it helps solve your problem.
barnesmar
Posted on Feb 15, 2009
I had the same problem with my Onkyo TX-SV515PRO. In trouble shooting I found that R921 resistor was open. This is a .47 ohm resistor. I replaced it and the problem was solved. The unit is now working as good as new.
Posted on Feb 21, 2010
Solution 1 worked for me, although no "TEST" appeared and I didn't have to unplug it. I had the same problem as "same problem".
Posted on Dec 12, 2009
I can't turn on my onkyo receiver, its in standby
Posted on Oct 29, 2009
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
Tip
Download Onkyo TX-SR304 Manual
Download Onkyo TX-SR304 Receiver Users Manual
Have you misplaced your Pioneer Download Onkyo TX-SR304 Receiver Owners Manual?
Would you like a digital, searchable, pdf version of the Download Onkyo TX-SR304 Receiver Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR304 Receiver
Onkyo TX-DS676 Receiver
check that you have selected that option on both player and receiver.
optical setting. a lot of systems are defaulted to hdmi
Apr 12, 2014 | Onkyo TX-DS676 Receiver
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
Onkyo tx-nr509 Receiver not talking to Panasonic TV TX-L42E31B
Hello, I am sorry about your issue. If the cable is long from the receiver to the TV it may cause video issues. Please try a reset of the receiver by pressing and holding vcr/dvr and then on/standby. When display shows clear let go. The receiver will shut down. Turn back on and test. This procedure will take the receiver back to factory defaults. Thank you, CB
Mar 24, 2017 | Onkyo TX-NR509
Hdmi compatibility
Hello, how long is the cable from the receiver to the TV? Thank you, Onkyo USA
May 31, 2017 | Onkyo TX-SR706 Receiver
I have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Nov 04, 2009 | Onkyo TX-SR506 Receiver
Mechanical Error on 5 Disc Onkyo Exchanger
hello there,
If the unit says mechanical error on the display, unfortunately, there really isn't much that you can do on your end. it is more on the hardware part of the unit and this would have to go to a repair center of Onkyo so they can service it (under warranty if you have your receipt).
Jul 03, 2009 | Onkyo TX-SR606 Receiver
Receiver doesn't respond on remote signals
Low batteries can cause a symptom like this. Have you tried to replace them yet?...accordianman
Oct 04, 2007 | Onkyo TX-DS595 Receiver
Onkyo HTR500 Receiver Logo
2,500 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
