Question about Ricoh Office Equipment & Supplies
RICOH MP3500 I have a MP3500 and just purcahsed a toner - the copier is brand new. I put the toner in and I'm getting blank pages when I try to copy a page. I pulled out the fuser unit (green type paper on it) and there is no trace of toner on it. The unit that the toner goes into with the long metal roller is getting toner. So I don't know what the problem could be? Maybe a bad fuser? But the unit is brand new.
  • 15 Answers
Maybe theres no developer in the machine
Posted on Mar 02, 2009
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Dark back ground on ricoh affico mp3500 replace drum ,Blade pcr. nothing has changed on the copy
Sounds like drum unit not getting charge voltage to it. Check charge roller is in properly point end should face rear of copier and making contact with plate.
Jan 08, 2014 | Ricoh Aficio MP4500, MP3500 Kit
I cannot make more than one copy when I place the original on the glass of the Ricoh aficio mp3500 copier
To make multiple copies, put your original on the glass, press the number key for the number of copies you want, and hit the green Start button. If you have Sort, Stack, Staple, or Duplex selected (or if they are selected by default), you'll have to press # to tell the machine that you don't want to copy other originals as well.
Jun 01, 2010 | Ricoh Aficio MP1600SPF Copier
Blank copies on brand new Toshiba e-Studio 120
Did you pull the plastic tape off of the toner cart?
Feb 18, 2010 | Toshiba e-Studio120 Copier
I have a AFICIO MPC3500, AND A AFICIO MP3500, I
Hello sir; You needto pull out belt unit,replace cleaning blade in the cleaning unit.
Jun 23, 2009 | Ricoh Office Equipment & Supplies
Copies are half printed and half almost not printed (very lite)
If the copy count is around 150,000 or higher and you haven't replaced the developer as well, it should be replaced. That symptom can cause light copies if it hasn't been replaced every 150,000 cycles.
Aug 23, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Patchy Prints
I believe that the Heat roller in the Fuser has a build up of toner on it(in some areas) and as a result is not fully fusing the toner into the paper. when you use a thick setting you are actually slowing the speed down to allow more heat to the toner. the thicker paper causes more pressure allowing the toner to fuse properly. I would say you need a new Heat roller and possibley a pressure roller. You could try running 20 copies of a blank white page. Sometimes this will help. Poor fusing can also cause a previous image to come up on the next page or repeat itself down the page. A service call is in order if this does not work.
Hope this helps
Dave T
Mar 29, 2008 | Ricoh 6513 Copier
Error Message SC320
We are buying a new machine! The price of the motor and labor is more than the machine is worth.
Feb 06, 2008 | Ricoh Aficio 180 Laser Printer
Toner lines when I print
I don't think it is anything to do with the toner cartridge as this doesn't put the toner on the page seems to me that the drum unit is faulty either the cleaning blade has failed or the charge roller. Best thing to do is call a service engineer or copier company that deal with Richo or Rex Rotary.
Thanks J
Nov 18, 2007 | Ricoh Aficio 180 Laser Printer
119 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
