Question about Dryers
Melted crayons over an entire load of laundry out of the dryer.
    Sergeant:
    Champion:
  • 324 Answers
The easiest thing to do would be either try to clean it or replace the drum.
Posted on Nov 11, 2008
When I do a wash my dark clothes have white streaks after drying. What do I do?
find the crayon or chalk in the machine. To isolate the issue, line dry some clothes and see if they come out ok.
Jan 07, 2015 | Kenmore 9781 Electric Laundry Center with...
Can you get melted crayon out of clothes if they were dried?
Sorry but after5 kids, no I have not found anyway to remove melted crayon.
Apr 07, 2014 | Crayola Classic Color Pack Crayons...
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Crayon removal
Ahh, children and their creativity! :) Here's one solution I personally know works...Using a hair dryer, warm up the area of the chalkboard where the crayon is holding it a couple inches away from the board. The crayon will become melted and then you can wipe it away. You may want to follow up with a good grease cutting dish soap like Dawn. I find this gets the area really clean after. Another solution is a Magic Eraser by Mr. Clean. They are just scrubbing sponges if you've never used one. They work great for lots of things but WATCH OUT...they can remove the chalkboard surface if you scrub too hard or for too long (the same with other surfaces as well). But they do cut greasy areas up to get the "de-greaser" in like detergent.
Hope these solutions help you out!
Jul 28, 2012 | Crayola Classic Color Pack Crayons...
Melted crayon all over my car upholstery
To remove melted crayon from upholstery:
1. Scrape away melted wax from the upholstery as much as you can using a blunt knife. 2. Put a brown paper, or butcher paper (glossy side down) on top of the affected area then using the tip of a hot flat iron, melt the crayon until it stick to the paper. 3. Let the paper cool then lift it away gently from the upholstery. 4. Dab a small amount of denatured alcohol to remove any remaining stains then finally clean the affected area with sponge and water.
Hope this help. Goodluck!
Jul 19, 2011 | Crayola Classic Color Pack Crayons...
How do I remove crayon wax that melted in the sun onto my wrought iron deck table
There are a few methods. You can take ice cubes and place them on the crayon wax until it freezes. It can then be easily removed. You can also place a paper towel on the wax and use an Iron to heat the wax until it melts. The paper towel will absorb the wax. Then use a dryer sheet to remove anything left over.
Jul 10, 2011 | Garden
Crayon melted on a car seat
Here's a detailed explanation:
http://www.wikihow.com/Remove-Melted-Crayon-from-Car-Seats
Jun 21, 2011 | Crayola Classic Color Pack Crayons...
Help getting crayon out of dryer.
If they are globs you can freeze them by rubbing with an ice cube and scrape them off. If the residue is thin like a coat of paint use denatured alcohol or paint thinner to rub them off. Make sure you leave the dryer door open several hours after using solvent inside to air it out. Do not use the dryer immediately after using solvent or there could be a fire hazard.
If the crayon residue is on the clothes, you can put piece of absorbent paper (like a paper grocery bag) over the stain and iron it. The heat will melt the crayon wax and the paper will absorb it. You may have to do it several times to get it all out. Denatured alcohol or paint thinner might be needed to get the final stain out.
Jun 29, 2009 | Dryers
Orange crayon melted all over the drum of drier and I cannot get it cleaned. Any suggests?
You now have hot melted wax coating EVERYTHING, I bet.
First, unplug your dryer, for safety.
Now take some turpentine or wd-40 and dampen a cloth with it.
Scrub, scrub away.
once it's clean(will take a LOT of elbow grease), you'll want to clean up the solvent.
A wash-cloth, dampened with soapy water, will do a pretty good job here.
Finally, leave the machine OPEN for a good solid day/night.
This lets any fumes remaining from the solvent escape.
this is important, if you don't want to blow up your dryer when you next start it up.
Jun 01, 2009 | Whirlpool Dryers
Dryers Logo
53 people viewed this question
Top Dryers Experts
