Question about LG LMVM1935 Convection/Microwave Oven
Microwave Keypad not working
My LMVM1935Sb is plugged in, there is a light in the microwave when you open the door. Screen shows the correct time. However the keypad, the Light and the Vent Fan button are non-responsive. Is this a bad circuit board or possibly a fuse? (I tried the parental lock trick and that did not work.)
  • 4 more comments
  • Drew James Nov 06, 2006
    Holy Cow! My wife said she was cleaning the microwave right before it stopped working. As an update the Light/Fan button has come back (working) but nothing else. How difficult is it to replace these keypads and can I do it on my own (where would I get one), or should I have a professional come and do it?
    Again top notch response, thank you very much.
  • Anonymous Dec 27, 2007
    when i was cleaning the microwave with water i sprayed a littl bit at the exhaust fan area.after few minutes the keypad is stops working properly. what should i do?
  • Anonymous May 11, 2008
    KEY PAD IS NOT RESPONDING WHEN WE TOUCH IT.
    I UNPLUGED & PLUGED BACK IN .
    THE DISPLAY ASKED ME FOR TIME OF DAY.
    AGAIN KEY PAD NOT RESPONDING.
    LIGHT COMES ON INSIDE THE MICROWAVE WHEN DOOR IS OPENED.
    ANY SUGGESTIONS ??
  • Anonymous Jul 09, 2008
    had the same problem unplug and leave it over night and mine started working
  • kdcsandiego Feb 02, 2009
    Mine is actually the LMVM2075ST which I bought in 2007.  Exact same issue. Called LG which said I had to repair myself.  Did anyone have any luck with the company support.  It is ridiculous how much I paid for this faulty product.  I thought LG was a good brand.
  • karrelpascal Feb 11, 2009
    my keypad is not respoding
  • LG Master
  • 9,149 Answers
This model does have a child lock. If it's on, the display will say "LOCKED". It is turned on and off by holding dfown the "0" key for 4-5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Repost if you need more help.
Posted on Nov 05, 2006
  • William Miller
    William Miller Nov 11, 2006
    You can call LG / Goldstar at 1-800-243-0000 (select option 2) to order parts. You might also ask them if they have parts distributors or if you have to order direct from them.
    They may call the part a keypad, membrane keypad, membrane switch, etc. It may come separate or with the control panel frame. That second way is easier to swap, but costs more.
    BUT - Make sure they don't try to just steer you to a local repair shop before they are clear that you want to buy "repair parts" yourself.
    Otherwise, you can try calling a couple of local appliance parts companies in your Yellow Pages.
    If they sell just the membrane keypad / membrane switch, then you can essentially peel off the old one and stick a new one on.
    You do have to take the oven apart, and you need to observe a few precautions. You can find my crititcal safety info file by doing search on Yahoo.com (not Google) for:
    microwave safety.txt
    If you decide call a local shop to do the work, I would recommend one that is "authorized to work on LG microwaves under warranty". Ask them just that when you call. They're more likely to have the repair manual and hotline access to get parts quickly.
    Good luck.
  • William Miller
    Two other things!!!
    Sometimes (not often) you can get lucky and find that there is still some moisture on the circuit board and that the keypad is not bad.
    Then you can carefully blow out the moisture with an air compressor or maybe use a heat source to dry it out.
    Also, some residue can remain inside the keypad connector. Here's an excerpt from my help file on that subject:
    If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board. To check that:
    1. Be sure the oven is disconnected from the power line while you are taking it apart.
    2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
    3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
    4. Then the keypad strip will lift out. Clean both sides of the end of the strip with alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
    5. Put the keypad strip back in, making sure both sides are down fully.
    6. While holding the strip down, push the connector back down to lock it.
    7. Try the keys again with the door closed.
Heat the keypad with a hair dryer. The problem is generally moisture. After a minute or two or three of heat, the keypad works. Did so on a Sharp, Panasonic and Black & Decker.
Posted on Jun 12, 2012
Keypad quit working on similar LG model. Buy replacement keypad for $30 at repairclinic.com. Turn off power, remove two screws on top. Take top cover off. Remove control panel on right via two screws (it folds down on two plastic tabs at bottom. Remove two wires, wire harness (has clip on back) and remove control panel. Keypad ribbon is removed from circuit board by pulling up on sides of black connector. That slips up lock on ribbon allowing ribbon to be removed. Keypad is stuck to face with sticky stuff so remove at face by peeling off corners and pulling loose. Replace is opposite of installation.
Posted on Aug 16, 2010
Replace Keypad
Posted on Oct 31, 2012
Sir,
My micro oven model no.MS-2342AE
Micro oven start button on key pad is not working please let me know how to set it right
rajalakshmi
Posted on Jun 24, 2008
I have LG MICROWAVE MODEL NO MC 7647UL IT SHOWS E10 PROBLEM AND TOUCHPAD IS NO WORKING PLS GUIDE ME HOW TO REPAIR IT
GOVIND 9414552320
Posted on Sep 06, 2012
4 Suggested Answers
computafixa
  • 317 Answers
SOURCE: No key's work. Display and inside light is working
The Keypad is either faulty, or disconnected. Open the case, and remove the screws, holding the outer shell on. Inside, there should be a small board that covers the Keypad. Check to see if there is a ribbon cable, or some other type of connection going from the board to another part of the microwave. If all of the wires are connected, then you will probably need to replace the keypad.
Posted on Jan 26, 2008
MicrowaveSvc
  • 9149 Answers
SOURCE: How to replace keypad on LG Microwave
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
heatman101
  • 43501 Answers
SOURCE: Part of the keypad on
The keypad has gone bad...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Jan 15, 2011
GE Microwave (Over the Range: Model HVM1540DPBB) was stopping operation. It would beep, and the display would show garbage. I would unplug it, then plug it into the outlet, then it would display "keypad...
make this test and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 02, 2013 | GE Microwave Ovens
Jan 26, 2008 | LG LMVM1955 Microwave Oven
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwwave is not heating,
Hello
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
My oven is not heating anything although everything else seems to be working fine. Your site said i may need a multi tester, what is this and where might i find one cheap.
Oct 04, 2011 | Microwave Ovens
F-6 showed up on my microwave window
self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "?" is displayed...
F6 ?Microwave Relay Failure: Check the microwave relay.
Jan 26, 2009 | Whirlpool MH7140XF Microwave Oven
LG LMVM1935SB OVER COUNTER MICROWAVE
The unit will work just fine on the counter, but obviously the lights underneath won't show and the exhaust fan won't be of much use.
Otherwise, it's perfectly ok!
Jun 02, 2008 | LG LMVM1935 Convection/Microwave Oven
Keypad doesn't work
check control panel and clean the control circuit, any moisture is there clean the circuit. any dry solder is there check overall circuit and confor it ...door switches and sensors
Oct 26, 2007 | Emerson MW8779W Microwave Oven
LG LMVM1935 Convection/Microwave Oven Logo
16,691 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
