Question about Delphi Roady2 SA10085 XM Radio Receiver with Car Kit
Channel programing for presets A B & C
I have a Delphi Roady2 and I have misplaced the instruction manual for information on how to program the A,B, & C presets. Does anyone have access to this manual?
  • mitcheloz Dec 28, 2008
    I also need the manual as mine was lost.
Http://www.xmradio.com/pdf/hardware_support/delphi/roady2_guide.pdf
Posted on Dec 28, 2008
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
Sep 15, 2012 | Haier HL24XLE2 LCD TV
I have an older model radio.. Delphi Roady 2.. gets powe to the docking station to the removalable unit but screen display will not light up.. any suggestions???
Probably the cheapest solution is to buy a used Roady2 off online bidding service like ebay and then pay the $15 to XM to switch radios. Delphi no longer makes Roady2. Probably could not repair for a cheap as you can buy used radios (around $25).
Nov 27, 2010 | Delphi Roady2 SA10085 XM Radio Receiver...
Owners manuel
XMradio.com has many manuals available, as would Delphi
Jul 12, 2010 | Delphi Roady2 SA10085 XM Radio Receiver...
How do I get to radio tune
Turn XM Roady2 'on' using the POWER switch. Go to MENU and go the FM Frequency. Select your frequency of an empty channel in your area, then turn off the Roady2 using the POWER switch. Do NOT do this by turning the car on and off as it tends not to save any settings when you do that. Always use the POWER button. Also, the website 'Radio-Locator' has a utility that will help you find an EMPTY FM channel in your are for your XM radio to use! Good luck and let me know how it works out for you- okay?
Jun 12, 2010 | Delphi Roady2 SA10085 XM Radio Receiver...
I need a manual for my receiver: Delphi SA10085 Roady2 XM
I'm looking also for that manual also. Please email me if you find one, and I will do the same. Thanks, Vicki vicglanzer@msn.com
Apr 13, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi roady home kit won't change channels
Solved my own problem! Press the Preset/Direct button located just above the 5and 6 on the bottom of the receiver. You should now have" Direct" displayed in the top left corner of the display.You are now good to go.
Oct 26, 2008 | Delphi Roady Xt Home Kit Sa1017611p1
Roady2 unit
check your subscription, sounds like it expired... DUH!!!!
Feb 05, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
No Signal After Reconnecting Roady2
Try playing the Roady 2 through a fm radio with the audio jack(middle connection) disconnected and the FM Frequency & Fm Radio set to the same station. At least this will tell if the receiver is working. I suspect that you got an aftermarket audiojack for your stereo. Might want to check that. Go back to the manual FM Modulation setup instructions. Any FM receiver will work. Good Luck
Oct 21, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
XM Roady2 Built in FM Modulator not working
It's not in the menu selections because the Roady 2 does not have an internal FM transmitter. The Roady XT does though.
Feb 01, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi Roady2 SA10085 XM Radio Receiver with Car Kit Logo
159 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
