Question about HP DesignJet 1050c plus InkJet Printer
Want to print as close as possible to the edges of my 36'' HP 1055
I have an HP1055CM plotter and want to plot as close as possible to the edge of the 36" paper. I have been able to plot 34 1/8".
Can you help?
    Scholar:
  • 96 Answers
If i remember correctly you can not do edge to edge on this printer. you may have the reached the outer limits with your current configuration. sorry this is not the answer you are looking for.
Posted on Oct 01, 2009
Plotter wont recognize edge of clear films when loaded from a roll or sheet. recognized plain paper fine
I would check the sensor on the carriage that detects paper. It might be dirty enough that printer cannot detect the subtle edge of the clear film. It is the blue light that turns on on the bottom of the carriage when you load paper.
Apr 18, 2015 | HP DesignJet 1050c plus InkJet Printer
Image prints at the edge of the canvas
you should check the paper size loaded at the driver open devices and printers- choose HP DJ5500 driver - right click and open Printer properties-click the paper/sizes tab at the top-check that the paper size is set to ROLL- then set roll size ( 24"=A1--36"=A0---42"=A0/2A0)
now when you try to print make sure that the printing application ( EG paintshopPro) has the correct Page size (under document Properties)
and that your not strectching to fit or using the overprint commands within your printing application. the plotter should never be allowed to overprint as this model has no ay of clearing the excess ink that would be left on the platten
Dec 24, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Printer cutting off 5 inches from finished size from InDesign
teresa_marti,
Try to rotate from lanscape to portrait, or if plotting form Acrobat check auto rotate and denter from the properties. Since it pltted before and no resizing was don it has to be the printer preferences.
randy320sgi
Jan 07, 2009 | Adobe InDesign
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
Designjet 1050C
the plotter measures the media automatically. There is no size setting,only type of media.If you want to print on 8.5x 11 only a few times,load a sheet to print on by simply lifting the cover an aligning the sheet on the blue lines ,on the right side.If you plot a lot,I suggest get a 11" x 150' roll.
hope this helps
Nov 09, 2007 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
79 people viewed this question
Ben Johnson
