Question about ViewSonic VP2130BH Monitor
Changed Cables on back of computer/monitor
And now it's in 32 bit color. I thought it could be in millions of colors. It feels all giffy. Text is no longer crystal clear.
I use XP and a Dell.
  • mollyeyres Nov 13, 2008
    I tried it and it didn't work. I think it's more complicated than that and has something to do with the cable.
    I really did like the quick and friendly support I received, though. :)
  • 108 Answers
32bit is 16.8 million colors - Goto display properties and raise the resolution all the way up (move slider to far right) to fix giffyness
That should fix you up.
G'luck
Posted on Nov 10, 2008
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
My monitor setting will not stay set on 32bit, it keep on going back to an low 8 bit setting that cause my colors to be off. How can I make this stay on the 32 bit. I have a Phillips 107MB 17 inch/CM2300...
The color bit depth is controlled by your PC Video card, monitor will show what it is being fed with. Please check to see if you have correct video card driver installed in your PC and the video card has enough memory to provide the 32bit color depth.
Jun 27, 2010 | Philips 107E61 17" CRT Monitor
Monitor lost resolution
itz probably corrupted software/driver or graphic adapter..
try reinstalling the drivers..
but 1st open control panel->display->click on the 'Settings' tab->Color Quality= (Highest) 32 bit; Screen Resolution= 1024x768 pixels (atleast)..
..try contacting ur system admin/vendor....
Oct 27, 2009 | Computers & Internet
The monitor only displays either 1920x1080 resolution with Low (8 bit) color or 800x600 with High (32 bit) color. I have uninstalled the video card and monitor drivers and reinstalled them a million...
It appears that your video card does not support that resolution and color depth. If you've installed all of the proper drivers from the manufacturer, re-check the maximum specs - sounds like you're looking for HD (1080) and the card can't deliver in full color (32 bit).
Jun 07, 2009 | Computers & Internet
Screensize of acer 5670 laptop
Yes the TV could have changed your screen settings (probably to 640X480 resolution).
Go to the Control Panel, then click on Display, then the Settings TAB, then change the Screen Resolution to at least 1024X768 pixels or higher to suit your requirements.
NOTE :- The higher the resolution the smaller Icons and text will be displayed also a lower color quality display ie the best is 32 bit color.
Jan 13, 2009 | Acer Aspire 5670 Notebook
Color problem
There are three Cathod Ray guns responsible for the millions of colors.All colors are produced by mixing the three basic colors namely Red Green and Blue (RGB) at suitable proportion. If any one of the three guns fail firing then we get improper colors. This can be rectified by
(1) hitting the monitor at the back by keeping it on a pillow the screen facing down - it will reolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contaction.
(2) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed)
TRY YOUR LUCK
ProfSweetlin
danielswweetlin@gmail.com
Jul 15, 2008 | Samtron 76df 17" CRT Monitor
Color quality
this is normal function of the programs some programs do not reset your resolution so you may have to do it manually. candy land did this repeatedly in my daughters computer.
Feb 13, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Aten Master View KVME CS1774 Wavy Screen
This is a fairly common occurrence, typically due to signal loss. The longer the total cable run (monitor to computer connector) the less loss you will have. The longest KVM to computer cable I can use reliably these days is about 12-15? at 1024 x 768 at 32 bit color or 8? for 1280 x 1024 at 32 bit color. Things you can do to reduce loss: -Reduce the length of the total cable run. -Increase the quality of the cables used. I only use low loss cables now and have far fewer issues. -Change the video card, some cards can push a signal a longer distance that others. -Reduce the resolution/colors the video card displays. -Try a different monitor or if possible use a different (low loss) cable to connect the monitor to the KVM. Let us know how it turns out or if you have any other questions.
Jul 04, 2007 | Altusen Aten MasterView CS1764 4-port KVM...
Color changes and flickers
To prove which Card or monitor are you in the position of either A- getting hold of another monitor or B Another computer connected to troublesome monitor Either way will establish which is the troublesome one. Then come back
May 08, 2007 | HP A4033A 20 in. CRT Monitor
Why are my pictures jagged when I view them on my computer?
Your monitor may not be optimized for viewing images. For the best on-screen viewing, set your monitor display as follows: For computers running the Windows operating system: Select Start > Settings > Control Panel > Display. In the Display Properties window, select the Settings tab. From the Color Quality drop-down menu, select the highest setting your monitor will allow (usually 24 or 32 bit). Drag the Screen area slider to either 800 by 600 or 1024 by 768. Click Apply, and then OK. For computers running the Macintosh operating system: Access the Monitor Control Panel. Set the color to Millions of Colors.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
ViewSonic VP2130BH Monitor Logo
35 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
