Question about Tascam DP01 All-In-One Recording Package Microphone
Trouble powering up
When I try to turn on my DP-01fx, most of the time it doesn't boot up. The LCD shows some random display at half-intensity, the drive doesn't spin, nothing. But if I keep trying repeatedly, eventually it powers up. After it's been on and warmed up, I can cycle power and it boots up fine.
  • Ellen Pratt Feb 08, 2009
    My Tascam DP-01FX/CD was working fine until yesterday. It started booting up and seemed to freeze. None of the buttons functioned. I had to turn off the main switch. Today, it started up normally but after mastering 3 short songs, froze. Now it won't boot up at all. I have a lot of my songs backed up onto CDs but not all and am afraid to send it out for repair as I'll probably lose everything. Help!
    Novelist:
  • 189 Answers
I would suspect the power adapter might be bad. You can use an after market one as long as it complies with the AC power specs given in the manual.
bd.
Posted on Nov 12, 2008
Tascam DP-01FX/CD wont turn on
Refer to your manual (1st) It appears that "maybe" your unit may be
locked - until you get through the menus - and type/press EXIT.
If you don't have a red indicator light - lit. Turn off power switch (rear)
and unplug unit for 1 minute. Plug in - then turn on switch (rear)....if
still no red indicator light....you'll need either Tascam or Samsung
tech to service your unit. Good Luck.
Feb 28, 2014 | Tascam Digital Portastudio Dp-01fx/cd
Tascam dp-01fx system 80 error It says " No CD
hey mate i got no solution for yah but if yah work it out e mail me man i got the same problem
da_monk_bomberman@hotmail.com
if i can get some info on it ill contact yah ok
Dec 08, 2010 | Tascam DP01FX All-In-One Recording Package...
I have a Tascam DP-01fx/cd that after powering on it reads sreset error :12 please power off. How do I fix this so I can use the machine again?
Jan 02, 2010 | Tascam DP01 All-In-One Recording Package...
Dp-01fx tascam
Since the unit powers up and displays an error message it means that the power supply is working to some extent. The hard drive is probably malfunctioning and needs to be replaced. The DP-01 I have uses an 40 pin IDE 3.5" hard drive so finding a replacement should be easy unless it needs special formatting like TIVO drives.
As for the first solution - why do you think a PC hard drive needs -5v? The PC drive power connector has four pins - two grounds, 5v and 12v.
Mar 30, 2009 | Tascam DP01FX All-In-One Recording Package...
No HDD:20 Please PWR OFF
It means the harddrive has crashed. I have the same model. It is a manufacturer flaw. You can try saving your recordings on external devices or contacting Tascam directly.
Oct 05, 2008 | Tascam DP01 All-In-One Recording Package...
DP-01FX/CD Problem
nslo, tell him to try replacing the power supply first, power supplys burn up ALL the time, as long as the plug fits and it has a rating of equal or greater amperage, same voltage, equal to or greater watts then it will work. Those variable voltage multi plug ones they sell at k-mart work but I've never had one that lasted long.
Jul 09, 2008 | Tascam DP01 All-In-One Recording Package...
DP-01FX/CD sound quality of CDs
Nothing really specific other than to make sure you are recording as close to 0 db as possible without going over. Your master fader also needs to be set at 0db or above as this effects the volume when mastering.
Commercial CDs use a lot of compression to attain volume levels which aren't attainable without it. You should however be able to reproduce onto CD the volume levels you are hearing on your Tascam without resorting to compression.
To troubleshoot, you might want to try exporting your master tracks as wav files onto your computer via usb and then listening to them there. If the volume is low there you aren't creating master tracks with good volume (see above: master fader level), if the tracks sound good as wavs on your PC, then burn them onto a cd from there. If that CD has proper volume then you may have some problem with your Tascam CD burner although I've never seen a situation where a burner actually caused low volume like this.
Best of luck.
BD
Apr 21, 2008 | Tascam DP01 All-In-One Recording Package...
C.d tray
Hold down "Shift" and press "Exit" at the same time.
Nov 12, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
95 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
