Question about Whirlpool Duet GHW9150P Front Load Washer
Runs intermittent faults F-70
My wifes machine (just a few monts out of warranty)runs sometimes and just quits sometimes with a Fault F-70. I unplug it for a while then plug it back in and may or may not work. It is a front load washer model WFW9200SQ00. I am an electrician by trade but have never worked on it before. Not even sure how to get into it to check for loose connections. Any help would be greatly appreciated since we live in the country and the closest repairman is about 50 miles away.
  • 4 Answers
The Duet washer is a good machine, just unfortunate Whirlpool engineers used oxidative circuit board coatings. All the circuit board connections are oxidizing causing the machines to have faulty connections. We have fixed the problem using this information.
UNPLUG the machine first . Take the top off (3 screws in the back) , remove the mother board box from the frame housing and remove the lid. Now you can see the circuit board.
Carefully remove ONLY one (clip plug-in) at a time. Scrap with a (knife or sandpaper or steel wool ) the edge connector where that plug was, on the circuit board removing the oxidated metal (it may not look oxidated but must be cleaned), Next put ( vaseline or mineral oil) on the edge connector where that plug was, NOTE: Vaseline or mineral oil is a non-conductive oil and will not effect electronic operation but will prevent further oxidation and the erratic operation of the mother board will cease.
Now do the next plug and repeat until completed.
NOTE: We recommend only one plug at a time so you do not get confused where each plug belongs.
Put the cover back on the mother board box and reattach to the frame, then put the lid back on and screw it down. End of any problems.
Posted on Nov 11, 2008
I found a fuse F4 250V. T1.6A blown. After replace it and turn on the power, my control panel, PSC box and motor doesn't have any power.
Mostly a fuse doesn't fail without a good reason. Sometimes the fault is intermittent and replacing the fuse makes the machine or device work again for a long or short time though it is almost a forlorn hope.
Best practice is to thoroughly check and discover the cause of a failed fuse before replacing it a second time (there usually is a second time).
In your case the reason the fuse failed was probably something else failing in a quite permanent way rather than an intermittent way. It is a nuisance but at least a permanent fault is easier to find than an intermittent one.
The wiring and internal circuitry will need systematic checking both visually and electrically.
Mar 28, 2016 | Sewing Machines
Lamda sensor wiring
That's great, Alan, good to hear. Guess you don't need an answer for that! Maybe it will help others looking for a solution to their problem.
Oct 04, 2015 | Cars & Trucks
Intermittent no spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Most of the time it takes two cycles to get load dry
Sounds like an intermittent fault on the heating coil (or possible intermittent pilot failure). Or thermostat out of calibration (but I doubt that last one is likely)
This fault sounds a bit dodgy and I'd recommend getting a qualified appliance serviceperson to troubleshoot this.
May 10, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Unstable idle
You will need to check the Mass airflow sensor and the Idle position sensor.
May 09, 2009 | 1996 Nissan Maxima
1996 monte carlo fault codes po300, 441, 705,
THESE ARE FROM THE GM CODE DIFINITION MANUAL, U NEED TO TAKE THIS TO THE DELAER, U HAVE SOME SERIOUS PROBLEMS TO GIVE THIS MANY CODES.
P0300 - Engine Random Misfire Detected
P0441 - Evaporative Emission Control System Incorrect Purge Flow
P0705 - Trans Range Switch Circuit
P1106 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge
P1662 - Cruise Lamp Control Circuit
P1672 - Low Engine Oil Level Lamp Control Circuit
P1870 - Transmission Component Slipping
Mar 24, 2009 | 1996 Chevrolet Monte Carlo
W640 - Water Outlet Fault
I solved this problem this morning, after several months with intermittent "water outlet fault" error messages.
Our pin trap was cleared many times over the months. The propellor turned freely. However, the problem persisted.
So I unplugged the machine, removed the back panel (8 or so hex screws) and located the point where the drainage hose meets the water draining pump. I then separated the hose from the pump and found 2 United States 10-cent pieces lodged together with gunk that effectively blocked the drainage hose. 10-cent pieces ("dimes") are the perfect diameter to get stuck there and not appear in the pin trap where you could easily see and remove them.
Three loads later, the machine is working according to spec. Hope this helps.
Apr 09, 2008 | Asko W640
Hoover Whisper HD97E
Try checking the water level, and level switch? Is the outlet hose high enough of the floor? If you tip the machine back you should see one or two clear plastic tubes, take one end of these and blow through them and the do it the other way round.
Nov 26, 2007 | Hoover 24 in. DT999 Free-Standing...
Whirlpool Duet GHW9150P Front Load Washer Logo
163 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
