Question about Sony MDS-JE520 Mini Disc Player
MDS-JE320 Hello,     I have the same problem with my MDS-JE320 that was brought up by that other guy. It makes a loud clicking noise when no disc is inserted and it also reads every disc as PROTECTED even if it isn't protected. Is there a quick fix for this or should I just trash the unit, after all it is old technology.
  • 4,234 Answers
The loading mechanism needs to be repaired or replaced. This is a common fault. Unfortunately, this is not a really cheap fix. Usually the loading carriage needs to be replaced at a cost of about $40 or so/
Dan
Posted on Dec 02, 2008
  • osfsf Nov 10, 2010
    Dan, I wonder where could I find someone to repair the Sony MD Deck Player in Singapore.
  • ABRsvcs Nov 10, 2010
    I am located in the US and can't really help much. You need to locate an authorized Sony servicer. They will have access to the service information required to repair this. Parts are still available for these units (at least in the US).
    Dan
Stuck in eject
Wow. A cheap MD deck from 1998. Brings back memories.
The last time mine did that the sticky label came off and jammed up the mechanism.
Take the cover off and see what you can do by hand. Be REAL careful not to touch anything that looks electrical!
Jun 13, 2012 | Sony MDS-JE320 Minidisc Player/Recorder
Is there any other remote that will work with Sony Mini Disc Player & recorder model mds je-320
Most Sony MD remotes will operate most functions on this unit, almost all of the Sony MD remotes are available on ebay even the rare ones.
Jul 01, 2011 | Sony MDS-JE320 Mini Disc Player
I have humming noise from earphones connection Minidisc MZ -N1
Are you using an AC adapter, or running it on batteries? If 'wall-wort' AC adapter, that's the issue. If you're running it on batteries, sounds like a bad ground, try different earphone/headphones and see if the hum goes away. With the 2nd pair of headphones/earphones, does the hum go away, or if you wiggle the headphone jack back and forth a little bit?
May 02, 2010 | Sony MDS-JE320 Mini Disc Player
MD player windows keep saying "no disc" when a disc is inserted. This started after the door starting getting sticky opening and closing. Any help would be great. Thanks
The little switch that detects the disc is inserted goes bad quite often on all of these sony home MD recorders. Do an online search as I have seen a step by step approach on it's repair. Make sure to UNPLUG the unit before removing any covers and poking-around inside. Good luck,
Jan 17, 2010 | Sony MDS-JE320 Mini Disc Player
Sony minidisc MDS-JE320 Clicking problem
you seem yo have a problem with the disk positioning/insertion switch, the switch may have become misaligned or it has become intermittent. The switch is located on one of the circuit boards that is attached to the drive mechanics. It may not be easy to get to it without dissembling the entire player. You may want to download the service manual and have a look to see the placement of the switch. Here is a similar player service manual for your reference.
Hope this helps you.
Cheers
Feb 28, 2009 | Sony MDS-JE320 Mini Disc Player
3 connection leads inside
These are ground wires and can be attached to the chassis anywhere where they will fit.
Dan
Aug 18, 2008 | Sony MDS-JE320 Mini Disc Player
Clicking noise
Yup, you are right, the plastic gears are broken. You can buy new once and install them yourself or find a local repair shop that can do this for you.
May 08, 2008 | Sony MDS-JE320 Mini Disc Player
Problem with the mds-je320
Hi there, it seems that one of the sensors is bad. Please contact me at LIVE session. Arpi
Sep 30, 2006 | Sony MDS-JE320 Mini Disc Player
Sony MDS-JE520 Mini Disc Player Logo
192 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
