Question about RCA F32650 32" TV
RCA F32650 32" TV Will not turn on
Mine did exactly the same thing. Would you mind telling me what your quote was for this?
Thanks.
  • dannyg66 Dec 03, 2008
    I have the same model....will not turn on. Green light on top just blinks. Took it to a repair shop and was told that they would have to rebuild the entire power supply and would cost $400. I said forget it! What a crock....as it's only 4 years old. I will never buy an RCA product again!!
    Sergeant:
    Champion:
  • 346 Answers
Check rp27, 1mega ohm resistor in power supply
Posted on Nov 17, 2008
  • 26 Answers
Depending on the part that failed, the repair can cost anywhere from $100 - $300, maybe even more.
I need the code to get rid of the region code error on my RCA L26WD26D
I had exactly the same issue, and after a week of searching the web for the answer to this question. I posted a pdf of the page from the service manual that helped me fix the issue here: http://www.highdefjunkies.com/showthread.php/1817-The-Official-quot-Service-Menu-Access-Codes-Request-Thread-quot?p=353717#post353717
To fix mine, all i did was turn the volume on the tv to zero, then on the tv set itself, hold down the volume down button and on the remote control hold the number 4 button down both at the same time for 2 seconds. The screen will say "initialization of factory dvd data." and my dvd player started playing my dvd's no problem. I wasn't able to set the region code to a specific number like some people need, but maybe the answer to that question is some where else in the manual I posted above. I've spent too much time on this already :-D Hope this was a help and good luck!
Sep 08, 2011 | RCA L26WD26D 26 in. LCD TV
I have an RCA M50WH72syx12, 50" DLP.
Yeah could be expensive if it isn't the lamp.
Mind you could be a little easier, might just be a fuse on the video relay. If you are confident in being able to open it up, check the relay that runs from the video input to the power capacitors and there should be a small fuse along that circuit.
If the fuse has a broken capsule then you may just be in luck. Failing finding a broken fuse, then I would agree with you on the bulb. But check the blub for any markings or cracks because they usually only make noise when the vacuum fails.
Hope this helps and good luck mate! :D
Nov 23, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I have a Rca NiteGlo Universal tv Remote. The book was burned in fire. Could you please give me the codes? At least for Haier TV? Thanks so much
Hi. You need to know exactly which RCA Niteglo remote you have, as there are many. Then you need to download the correct manual. I just had a problem similar to yours; mine is also an RCA Niteglo which was supplied with a VCR model VR629HFB (I only found out on the internet). It is a 2 component remote (TV/VCR only). Sadly, on the manual there are no codes for Haier TV. Good luck.
Oct 17, 2010 | RCA Televison & Video
Im having problems programing my sansui flat screen tv when i program my rcr311b universal remote it works up untill the point when the tv turns off after pressing the play button and releasing the reverse...
first wat are u trying to do,,,,,,in mind....wat way,,,,,to do wat....try going to get thing that can remote w/remote to do......reverse the plan of mind,,,,
Aug 27, 2010 | RCA RCR311B Remote Control
Tv willnot turn on
Mine just did the same thing on the same day, same tv. we bought ours from Walmart exactly one year ago and after spending time on internet, i have found that alot of us with the same tv have had same problem with no avail from RCA company or walmart. i can't get help from anyone and am ready to scream. Good luck. Others have told me that they have had repair man out and said that it was a malfunction is some type board that he has seen over and over in this tv and he advised to just buy another tv because it was too costly and the problems were going to keep coming with this specific model
Apr 06, 2008 | RCA P52812BL 52" Rear Projection...
Programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Apr 03, 2008 | Toshiba 42H81 42" Rear Projection...
36" rca tv
Mine did the same thing. Just happened to have a worthless Best Buy service contract. The tech came out and said that it was the power supply and or the fly back something or other. He then prodceeded to tell me that he could not get parts for my 2 year old tv. You might check with a local tv repair shop and get some estmates on replacing these 2 parts.but at 80-100 bucks and hour for labor....
Dec 04, 2007 | RCA F36650 36" TV
RCA 32v434t
Has anyone confirmed what the problem is? Mine wont turn on. The red light next to the power button just stays lit when pressed.
Oct 22, 2007 | RCA 32V420T 32" TV
RCA F32650 32" TV Logo
141 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
