Question about Nikon Coolpix 4600 Digital Camera
Camera frozen open, but isn't on
While transfering photos from camera to computer, computer froze. now the camera won't turn on, and is frozen "open" with the lens open. help. when I put new batteries in, it still won't turn on! so obviously can't "close" the lens, etc. Did I "fry" it when the computer froze and had to restart it?
  • Anonymous Mar 31, 2014
    Lens does not stay open when camera is turned on. New batteries! Inserted...still a problem. I am unable to take any pictures!?!
I also have this same problem - we bought a new camera after we were told that it would cost about the same to have it repaired as to buy new.
Posted on Jul 30, 2007
I had the (almost) same problem, im gonna send it in i think
Posted on Apr 20, 2007
While deleting photos camera shut dow
May I suggest the battery was very low. The Nikon delete routine shows a bright display after the file is deleted, this may take a bit of power. May I suggest you work on your files on your computer? That is, that the SD card out and work on the files on the computer. Now I suggest charging the camera and taking out the SD Card and then turning it on. If it works try it again with the SD card in.
Jun 20, 2014 | Nikon Coolpix S4000 Digital Camera
Frozen screen
Try first removing the batter for about 5 minutes to refresh the camera, then make sure also that the battery is fully charge...then after that check the camera again...
Hope that helps.........
Sep 15, 2008 | Fuji FinePix 2650 Digital Camera
Easyshare Z5120 won't transfer pictures to computer
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Mar 10, 2013 | Kodak Cameras
Ihave sony full hd HC1080 camera i can't transfer photos from camera
( CARD READER TO PC)
The best and easy way is took out the memory card from the camera & insert in the memory card Reader. Then connect card reader with the PC. Now open My computer and there you can find removal disk driver ( For Example G: ). Open the driver and copy all the folders from there to your computer. After complete the transfer open the folder. You will find all the photos there. b>OR
( CAMERA TO PC USED USB CORD )
Connect the camera with data cable and turn on the camera. After that open My computer and there you can find removal disk driver ( For Example G: ). Open the driver and copy all the folders from there to your computer. After complete the transfer open the folder. You will find all the photos there. http://www.ehow.com/how_2282213_transfer-pictures-from-camera-computer.html
Aug 09, 2012 | Sony Cyber-shot DSC-W130 Digital Camera
It won't allow uploading Lens keeps trying to open behind close cap
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 25, 2012 | Nikon COOLPIX P90 Digital Camera
My camera isn't connecting.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Jun 30, 2011 | Nikon COOLPIX S230 Digital Camera
I can't transfer my photos. Transfer doesn't come
Make sure camera is off. After you plug your camera into your computer turn camera on. This should open the program for you. If not, right click on START button, go to EXPLORE, find your camera in the list. right click on camera, go to OPEN WITH. Select the program you want to use and VIOLA, you're in.
Hope this info was helpful to you. Good Luck!
Jan 30, 2010 | Nikon COOLPIX S230 Digital Camera
I CLICK ON NIKON TRANSFER AND GET A BLANK WINDOW.
Try NOT connecting your camera to your computer.
Nov 10, 2009 | Nikon COOLPIX L18 Digital Camera
My pictures won't upload to my computer. ive uploaded them before so i dont understand the problem.i have a fuji z20fd.
My computer usually prompts me to uplaod photos when my camera is connected but it isn't doing that anymore. Why won't it upload my photos anymore?
Jul 30, 2009 | Fuji Finepix Z20fd Digital Camera
My c340 is unable to initialize photo transfer via usb once connected to the computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 11, 2007 | Kodak EasyShare C340 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
246 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
