Question about HP Office Equipment & Supplies
I am trying to print something from a web page on the internet and it will only print from the left to the right, leaving about 2 to 3 inches of info out. How do i get it to print the entire thing?
  • yvonnejo Nov 13, 2008
    The solution was excellent. Only now i have to try ;and figure out how to use the new browser. All in time i guess. Thank you so much.
  • jbland472 Jan 24, 2009
    I have the same problem. I was trying to print from Paint. After 20 minutes trying to make it work I gave up, recreated the folder binding on Excel, and found the same issue.
    I wouldn't mind switching to Firefox but don't see how this could affect me since I'm not printing from a browser anyhow.
  • 345 Answers
I would guess you are using Internet Explorer when you try to print this. Internet explorer has a bad habit of not printing the whole page. Go to a search engine and search for "Firefox". That is another browser and it will print the entire page when you use it to print out webpages.
Posted on Nov 11, 2008
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
Printing 2 and runs off page
check your print settings before you print anything. the left margin might be from the ink cartridge not going all the way over or it could be blocked by something. have you tried printing on just the internet alone? or have you tried printing on wordpad too?
Jun 20, 2010 | HP DeskJet 960c InkJet Printer
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
Hello Two days ago web images and logos on this PC/monitor started becoming fuzzy/pixelated. Also, web pages load slowly. Problem is seen with different browsers also. Desktop environment appearance is OK....
1)Go to Control Panel>Appearance and themes>display>settings>Make sure your screen resolution is set to more than 1024X768 and millions of colors.
You didn't download an accelerator for a modem, did you? If so, that is usually how the accelerator works, by deducting pixels from graphics. If that is the case, go to your accelerator and choose use original image settings. The other place we need to look is in browser settings and internet connections. See pics below. Make sure that compression settings are not too high.
2) clear your cache, cookies, and history.Instructions differ, but go to control panel>network settings>internet options. You can also check on your internet connection.
Lastly, if you have been making graphics for the web with Adobe, or another web program, make sure that you haven't changed your view settings in an effort to conserve memory in your editing programs. Sorry if I gave you redundant advice, I couldn't find your first post. Thanks, please continue to leave comments if your situation changes.
Text and graphics are totally different, so browse through you internet settings to make sure that you didn't accidentally changed something. You can choose reset original tools/option settings in browsers and Adobe if you are not sure where the problem comes from.
Nov 19, 2009 | Computers & Internet
Printer squeezes Web pages to left side of page and cuts lines
I found that the print margins on my browser were set incorrectly--four inches in on the right. I don't know how they got that way, and I found it only by looking at every possible setting on the browser. Thanks for your service, and I'll try it again if I ever need it.
Jun 02, 2009 | HP Office Equipment & Supplies
Hp6310 officejet all in one
here is solution..
Solution Step one: Make sure that the product prints correctly
  1. Print a self-test page from the product control panel, from Windows, or from the product software. (See the product user guide, available online, for instructions to print a self-test page.)
  2. Check to make sure that black and all colors (if using a color product) print on the self-test page.
    • If the self-test page does not print correctly, an issue might exist with the product hardware. See the product user guide, available online, for further troubleshooting steps.
    • If the self-test page prints correctly, continue with the next step.
Step two: Determine what portion of the page is set to print Many Web pages use frames. Frames divide the screen into multiple windows. Follow these steps to determine what portion of the page is set to print.
  1. Click the Internet Explorer icon on the desktop. The Internet Explorer window opens.
  2. On the File menu, click Print . The Print dialog box opens.
  3. Click the Options tab to view the print settings.
  4. Change the settings if required, and then click Print .
Step three: Change the Encoding setting in the Web browser
  2. On the Menu bar, click View .
  3. Click Encoding to view a list of encoding options.
  4. Check the Encoding settings.
    • If Auto Select has a check mark next to it, click to clear the check box.
    • If Western European Windows does not have a check mark next to it, select it.
Try printing again. If the issue continues, proceed to the next step. Step four: Check the page setup settings for the Web browser Web pages are designed to be viewed at a certain screen resolution. If the resolution of the screen is lower than the resolution of the Web page, the whole screen might not display or might not be printed.
  1. Make sure that Internet Explorer is open.
  2. On the File menu, click Page Setup . The Page Setup dialog box opens.
  3. Review the Margins information.
  4. Make sure that the margin settings are greater than or equal to the minimum printable region margins for the product. The margins vary slightly among HP All-in-One products. As a general rule, the settings should be at least the values shown in the following table. Side Margin Top Margin Bottom Margin 6.3 mm (0.25 inch) 6.3 mm (0.25 inch) 6.3 mm (0.25 inch)
  5. Make necessary changes to the margin settings.
  6. Click OK to save the changes.
Try printing again. If the issue continues, proceed to the next step. Step five: Print using Smart Web printing software HP Smart Web Printing is fast, free, downloadable software that enhances how Microsoft Internet Explorer and Mozilla Firefox print Web pages. Use HP Smart Web Printing for the following tasks:
  • Select text and graphics from any Web site
  • Save paper by combining portions of numerous Web pages
  • Preview and modify clips before printing
Thank you.......
Jan 29, 2009 | HP Officejet 6310 All-In-One InkJet...
Will not copy info. off the internet
Are you able to print from other applications like a microsoft word page, or a print test page. If thats the case than check your Internet options. If you are using an Internet EXplorer web browser than try to set all  internet settings on the option menu to default. This should resolve the issue. Else try to  use a HP 990C pritner. Add the 990C printer and try to print an internet page, it should work.
Jan 22, 2009 | HP PSC 1210 All-In-One InkJet Printer
I can't print web pages
What Internet programme are u using? Ie: Internet Explorer.. mozilla etc ! need info ..
Regards Faggly
Mar 27, 2008 | Office Equipment & Supplies
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
