Question about Mitsubishi MS17TN Air Conditioner
A/c shuts down after about 30 seconds
This is a Mitsubishi mini-split heat pump. Today it was 62dgrees inside this room, 65 degrees outside. When in cooling set at 59 degrees the heatpump would operate for about 30 seconds and shut down. When in heat it would operate normally without shuting off. In cooling the suction pressure was about 50psi. The smaller line is also not insulated . The suction line is coming back cold. Is ther a problem or is the cooler temps causing this by a sensor or something. I saw no low or high pressure switches. Thanks Bill Pugh
Sounds to me either a low refrigerant charge or low air volume over the evap coil (inside). There is a sencer for temps outside maybe it's tripping out on that.
Posted on Nov 10, 2008
The unit is on Heat, Fan Auto it's 36 degrees outside, Thermostate set on 73 Actual temp inside 70. Unit runs continuously. How can I get more heat. I tried Emergency heat and that doesn't help.
Have you cleaned the air return filters ? Wash them, don't vacuum or brush them. It damages the filter screen. Sometimes a thermostat will be out by a few degrees. If the filters are clean, try turning the temp down a bit to 65 degrees and see if the air con shuts down. ( If your room temp is showing 70, it should switch off the machine) If it doesn't turn off, keep reducing the temp by 5 degrees at a time and wait a few minutes each movement to see if and when it shuts down. If the machine keeps running, I would suggest your thermostat is shot and you will need a new one.
Jan 04, 2016 | Heating & Cooling
Why does mitsubishi split system heats room 5 degrees hotter than setpoint on remote
It could be something as simple as 'solar gain' adding heat through glass facing the afternoon sun....or maybe the remote is not in a location that senses the average temperture within the room. Maybe the remote is located in a slight draft entering the room.
If the remote was kept above a computer tower, the opposite would be the case.... the heat from the tower would keep the control thinking its warmer in the room than it is. The result would be a much colder room.
Mar 10, 2015 | Mitsubishi MUZ-FE09NA-1 MSZ-FE09NA-8 Mr....
Comfort star
Make sure the indoor filters are clean. The outside unit will continue to run until the indoor reaches the temperature you have selected. Dirty filters can throw the temperature out. Its common for outdoor units to freeze up when on heating mode if the ambient air temperature is below 5 degrees Celcius.. The machine should however, defrost itself. There could be a problem with one of the pipe or air sensors on the outdoor unit.
Feb 23, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
Outside unit freezing up and not heating up room inside
Check the defrost board in the outdoor unit... it should have a wire coming off pins that are stamped 30, 60, or 90. If the wire is on 90, then try setting it to 60 or 30. This just enables the defrost board to check the freezestat in minutes...the shorter amount of time, the less likely the unit will freeze up.
Dec 16, 2013 | Soleus Ductless Mini Split 9000 A/c...
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
I have a 18000btu LG mini split heat pump installed about 1 year ago in vacation home. In heat mode the unit cycles on and off when room temp is within 2-3 degrees of set point. Cycle on time varies...
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Oct 26, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Air flow is blocked
In the 65" TVS there are 4 or more fans One of these is not functioning Probably the one over the power supply itself This will cause it to heat very quickly and shut down in a matter of about 20 seconds.
only way to find out which fan is not working isw to remove the back.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Mitsubishi WD-65731 65" HDTV
WE have Amcoraire Mini split unit heat pumps. One is
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Nov 19, 2008 | Vornado TouchStone Vortex Heat 500 Heater
Mitsubishi MS17TN Air Conditioner Logo
322 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
