Question about Whirlpool LSQ7533JT Top Load Washer
How do you change the belt if it is slipping?
My machine is slippng, as if the belt is loose or has streched. How do I go about replacing the belt? the model is LSC8244BQO.
    President:
  • 878 Answers
GN. This model does not have a belt, it's a direct drive washer. It could be a couple of things. Is this happening during spin? If so you may have a worn drive block or something as simple as something between the tub and basket. The clutch and brake assy. could be failing. It's hard telling without being there. I will attach a couple of pictures so you can get and ideal...Catriver..post back.
Posted on Nov 05, 2006
  • Ron Marek
    Ron Marek Nov 05, 2006
    Number 1 is your spin tube and brake. 5. is your clutch assy. The other picture is a worn drive block
Handwheel slipping loose on white jean machine 1810. Cleaned and oiled, changed needle. Do I need to change belt?
Probably the belt is slipping. It could need to be tightened, but if it is old and frayed, replacement may be the best answer.
Dec 12, 2017 | Sewing Machines
The belts keep slipping off, brake foot pedal shudders and it just stops moving
I would guess that either the belt is streched or one of the springs on the pulleys is missing check all moveing pulleys for weak or missing springs
Dec 29, 2013 | Mtd 46" Dozer Blade, Fits All & Yard -...
The belt on my FEW 12 HOTPOINT FIRST EDITION has slipped off, the belt has worn it's self in to the metal part behind it. Is it not repairable or has the belt streched
Belt is probably stretched. You will need to purchase a replacement.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person if your's is a front loader!:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 17, 2011 | Hotpoint Washing Machines
What size replacment belt can I but for a 54inch cut cub cadet mower. And is there any suggestions on how to keep the belt from slipping off?
they changed the part number for that belt new # is 954-3068 B x 110.6 your old belt was probaly streched so when you install new one it should ride on pulleys correctly
May 05, 2011 | Cub Cadet Lawn Mower Deck Drive Belt...
Washer wont spin
You may have some small piece of clothing stuck in the water pump. Pull clothes out, empty water out, turn over and remove pump and check for obstructions. If nothing in there see if it is frozen from moving, if not belt may be loose by being streched. Replace belt if needed.
Apr 16, 2010 | GE Spacemaker WSLP1100D Top Load Washer
Treadmill is slippng badly
There should be an allen head bolt on each side at the rear of the treadmill going throughthe rear cover into the tail [rear] roller. Turn each one 1/4 turn at a time equally untill slipping is stopped. If belt tracks more to one side tighten slightly more on that side.
Feb 06, 2010 | Proform Exercise & Fitness
John deere 170 riding lawmower learching forwarn in 1st gear and slipping is clutch bad is there a clutch..maybe an adjustment?????
This is a classic symptom of a slipping belt. It lurches because belts do not wear evenly - they develop 'tight' spots - like the chan of a single cylinder motorcycle.
The belt will be slippng for one of two reasons - either it is simply worn beyond it's service life, or the 'clutch' - which is simply a spring-loaded jockey wheel on the belt which keeps it tight - is hanging up somewhere and not tensionng the belt properly.
Sep 21, 2009 | Garden
Belt slipped off machine
rotate pulleys while trying to reinstall belt. if belt slipped off on its own then belt is streched out. replace belt
Jun 20, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Drum not moving around although sounds like something internally is moving around. Husband has taken back of and can't see anything obvious
Take the back off put washing machine on spin cycle making sure not to touch anything so you don't get shocked and look at the motor maybe the belt is loose or broken if it is loose just tighten via the spring adjustment or if is old washing machine belt may have streched and needs replaceing if motor don't move maybe needs rewinding and is cheaper to buy new washer.
Jul 21, 2008 | Washing Machines
Servis washing machine belt slips off when on spin cycle
You dont stated the brand and model of your machine so all I can say is yes change the belt allways when this hapend to one of my client I change the belt becouse the belt is waring off and loose its trech condition loosing flexibility and slipping out wen ist run at high velocity....good luck and rate me....
Feb 17, 2008 | Washing Machines
Whirlpool LSQ7533JT Top Load Washer Logo
96 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
