Question about Lexmark Z715 InkJet Printer
Lexmark z715 problem w/printing
Feeds paper halfway, and I can hear the sounds of it printing, afterwards I see that nothing was printed. Also, states paper jam, but it's not. Good on ink.
  • codyw Dec 13, 2008
    when i turn on the printer it trys to feed paper for a while then it stops and it only does it when paper is in it.
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Posted on Dec 14, 2008
I have a lexmark z715 printer connected to windows xp. recently it stopped printing. the paper moves and the machine makes sounds similar to printing, but it doesn't print. i think the sound is s
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 23, 2013 | Lexmark Z715 InkJet Printer
PAPER FEEDS TO START, THEN PRINTING STARTS, BUT
Hi there
This is some imes only down to cleaning the rollers with some worm water cleanthem all and you may be in luck.
All best Pineworks
Apr 29, 2010 | Lexmark X5495 All-in-One &USB...
Even with new ink cartridge printer won't print.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
The first tip on this site should clear out the nozzles. Using warm water seems to flush the nozzles out better.
Mar 24, 2010 | Lexmark Z715 InkJet Printer
Printer feeds all the paper at once.
sounds like the separator pad is either missing or dammaged
Feb 10, 2009 | Lexmark Z715 InkJet Printer
Lexmark Z715 will not print but computer says it is printing
The Z715 needs a #50 black ink cartridge and a working color cartridge to print. To check if there ios ink coming out of your black or color cartridge touch the bottom of it to a paper towel and if you see a solid black blob or 3 blobs of Yellow, blue and red for the color then your problem is else where. If U are printing stuff from the internet sometimes the printer will try to use the color cartridge to print this so even though the black is working it comes out blank if the color is dry
Jan 16, 2018 | Lexmark X4650 InkJet Printer
Lexmark X1185 printer will not print color......everything else works fine
the ink is clogged not the cartridge but were the ink feeds into the printer. there should be a cleaner tab in the printer preference tab if available
Jan 08, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
The printer won't print/just changed black cartridge
Uninstall the printer, reboot and reinstall using your printer software/driver cd.
Dec 18, 2007 | Lexmark Z715 InkJet Printer
Lexmark Z715 InkJet Printer Logo
160 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
