Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
Apex gb4308 flashing blue screen and cycling channels
My newly acquired gb4308 is flashing a blue screen and appears to be cycling thru the channels one at a time with every flash. Only the blue projector is lighting up, but when I unplug the wire going into the verticaly oriented, metal enclosed board on the A/V (I think) board all 3 projectors light up and the cycling stops. No video or audio. Any ideas would be appreciated!! Thanks Ridler
  • 979 Answers
Sounds like a power supply problem to me. Could be caused by the actual supply, or could be a component failure elswhere...accordianman
Posted on Feb 18, 2008
No picture
Let your local TV repairman check it. Don't touch anything inside it nor open it.
May 26, 2009 | Apex Digital GB4308 43" Rear Projection...
Tv will turn on but nothing shows up
here is a simple test to know whether to call a technician,...first, check all connection including the antenna or cable lines to your unit.if not, tap the unit for 2 to 4 times.while tapping watch what happens to the picture.if the unit turn on or becomes okay, i suggest to call a tech.it needs resoldering or something inside has loosed contact.
May 11, 2009 | Apex Digital GB4308 43" Rear Projection...
Apex GB4308 43" tv have to set convergence each time I turn it on
Replace your STK ICs and look for Bad capacitor by vertical IC 100uf 35v.
Jan 14, 2009 | Apex Digital GB4308 43" Rear Projection...
I HAVE A BLUE RIBBIN LOOKING SCREEN GOING ACROSS MY SCREEN
this could be a flyback problem a cheap part but the labor may be as much as $600.00 the problem will get worse untill your whole screen turns blue
Dec 08, 2008 | Apex Digital GB4308 43" Rear Projection...
Problem with tv APEX DIGITAL GB4308
it sounds like your lenes need cleaned and alined
APEX GB4308
it very well could be a flyback ! a cheap part but hard to find for your brand!
Sep 23, 2008 | Apex Digital GB4308 43" Rear Projection...
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
TV has no vision , only one channel has sound
your tv is locked!
If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired. • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels. • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
http://vchip.atspace.com
Dec 21, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Apex gb4308 multi colored horizontal bow in middle or screen.
This is not an "STK" problem. Your problem is VERTICAL. You need to check your vertical chip for damage CN301 and check around it for any bad parts or loose connections. I've seen loose connections on the chip itself cause it to self-destruct.
Apr 11, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
50 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
