Question about Sony STR-DA555ES
PROTECTOR (FAN) error message - what next?
Hi, I have limited tech knowledge, but my unit is displaying the above error message when I turn it on. I am unable to use it. This is a US model but I live in the UK which means I can't get it repaired by a Sony dealer. Instead I'm looking for some advice that will allow me to ascertain the seriousness of the problem and whether it will be cost effecient to get it fixed. Many thanks! James.
  • candler Nov 18, 2007
    I have the same problem, but after a year, it seems that there may not be a solution available on this site. If you do actually have a solution, please forward it to mcupshaw@insightbb.com. I have done nothing to resolve the problem because I have no advice about the nature of the problem. All I can tell you is that nothing works when I get this message and it does not go away.
Look inside the unit. There is a fuse you can replace in the rightmost front of the unit. 125v 3.25A, I believe.
Posted on Feb 03, 2008
My printer hp laser jet pro 400 mfp475dn shows error 57.02
Hi
I have taken this directly from the User Guide
"57 Fan error Turn off then on
Description - The product has experienced a problem with its internal fan.
Recommended action
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for it to initialize.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the product power on.
If the message persists, contact HP support."
For future reference this manual can be found here:
http://h20565.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c02966093
and being in pdf format can be saved to the computer.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 17, 2014 | HP LaserJet Office Equipment & Supplies
Drum will not spin
While most Samsung dryer component failures will generate a trouble message on the display, a failure of the hi-limit thermal protector won't. If the hi-limit thermal protector has opened, it directly interrupts power to the drum motor. As a result, you can start a cycle using the buttons, the 'brain' will turn on the relays controlling the motor ( the faint clicking sound ) and run the cycle timer, but the motor can't actually run. And without drum rotation being sensed, the burner won't turn on either.
Solution is to replace the hi-limit thermal cutout, which is located on the 'nose' of the blower assembly next to the dryer temperature control thermistor ( which is slightly larger than the hi-limit thermal cutout ).
Also note that the usual cause of a hi-limit thermal cutout failure ( or a thermistor failure ) is ducts restricted by lint ... both the burner exhaust duct as well as the blower intake duct. Both should be disassembled and thoroughly cleaned while you have the dryer apart.
Feb 12, 2012 | Samsung DV448AGE Gas Dryer
Keeps stopping and displaying C1 error what is this and how do i fix it
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps
at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps
instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
May 13, 2011 | Washing Machines
Waher shows c1 what is my problem
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Press( stop/cancel) to clear the display.
If that does not help then, "C1 = Average current limit Or Instantaneous current limit."
draw greater than 5.55 amps at the motor windings
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a ca code what does this mean
Hi
Thanks for using FixYa. Error code CA means Average current limit. This error code will display if the load of clothes is more then the normal load. Also if current limit breaches then status signal comes back from the motor controller. The unit will return to standby mode and display CA. Average current trip occurs if the current draw at the motor windings is greater than 5.55 amps in 2 seconds. This error occurs if there is a problem with the drive motor, thermal protector or motor controller. Over-loading the unit may cause this problem.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error code - protector
Try disconnecting all the speakers from the back and turn the unit back on. If the "protector" display goes away, turn the unit back off and reconnect one speaker. Turn it back on and check for "protector". Repeat.
If you find that one of the speakers causes "protector" to appear, you either have a bad speaker cable or bad speaker. Try swapping each of those out to see what happens.
Apr 20, 2009 | Sony STR-DA90ESG
Power protector on sony surround sound system
Power protect is an error message that some thing is wrong in your sound system and requires qualified tech.
Normally that error message appears when unit got problem in amplifier output section, either it is speaker problem or some output chip is fried.
Feb 25, 2009 | Sony DAV-S400 System
Fan flow error 1611 I/O
The ProLiant DL380 G3 server requires that both primary and redundant fans exist in a specific configuration in order to perform optimally. Any deviation from the specified configuration will cause one of the above error messages to occur and the internal Health LED to illuminate. In a ProLiant DL380 G3 server without the redundant fan option, the server will shut down after the error message is displayed. In a server with the redundant fan option, the internal Health LED will illuminate and the appropriate error message regarding fan redundancy will be displayed. The purpose of this document is to detail the required configuration for both primary and redundant fans.
DETAILS Both primary and redundant fans in the ProLiant DL380 G3 server must be configured to meet specific requirements in order to avoid the error messages above and in some instances, subsequent shutdown of the server.
All primary fan locations (2, 4, 5, 6 and 7) must be populated with a fan before the redundant fan locations (1, 3, or 8) are populated. If a primary fan location is left unpopulated, the server will display one or more of the error messages shown above. In addition, the internal Health LED (the top LED on the front panel of the server) will display the status of the fans.
When the redundant fan option is used, all redundant fan locations must be populated. ProLiant servers do not support partial population of redundant fans. If any redundant fan location is populated without also populating all other redundant fan locations in the server, the fan system will not be fully redundant and one or more of the error messages above will be displayed.
Figure 1 below illustrates a ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy. The server airflow is divided into three zones: processor, I/O and power supply. Shared fans 4 and 7 each provide airflow for two zones. If a shared fan fails, the failure is experienced in both zones.
Figure 1: ProLiant DL380 G3 server configured with all eight fans installed for fan redundancy
The internal Health LED (the top LED on the front panel of the server) indicates failed or missing components. The internal Health LED should be observed to determine the status of the fans as follows:
RED LED: A red LED indicates that the minimum fan requirements have not been met. Minimum fan requirements indicate that all primary fan slots must be populated with functioning fans.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is red , then a primary fan has failed.
AMBER LED: An amber LED indicates that the minimum fan requirements have been met; however, requirements for redundant fan configuration have not been met. This means that all primary fan slots are populated with functioning fans, but at least one redundant fan has either failed or is missing.
  • If the 1611 fan "x" is not present (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan is missing.
  • If the 1611 fan "x" failure (where "x" is the fan location) error message is displayed at POST and the internal Health LED is amber , then a redundant fan has failed.
Note: In a redundant fan configuration, the error message fan system not fully redundant will also be displayed at POST if any redundant fan slot is left unpopulated or if a redundant fan has failed.
Nov 21, 2008 | HP Compaq ProLiant DL580 G4 (430811001)...
Canon Error Message
An E805 code has to do with the failure of one of the many fans within the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Oct 14, 2007 | Canon imageRUNNER 400S Copier
Sony STR-DA555ES Logo
487 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
