Question about Samsung Computers & Internet
Syncmaster 940s menu
Menu for syncmaster 940s is a disaster. I have put up with it for years but now it has totally defeated me. How do I turn off magic color demo?
PS I have worked in broadcasting technical and have no problem lining up three tube color cameras. But the the program for this monitor has brought me to tears. Something like your web site
  • 220 Answers
SOURCE: Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Posted on Jun 16, 2008
SOURCE: Samsung SyncMaster [Monitor] (22.0 - I need best settings
hi , any has got the drivers for this monitor , kindly let me know to download it . regrads
Posted on Nov 10, 2008
  • 120 Answers
SOURCE: Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Posted on Jul 24, 2009
  • 732 Answers
SOURCE: Samsung SyncMaster 940n monitor that turns on then goes black
rcpips, You may need to replace one or possibly 5 -8 aluminum can "electrolytic filter capacitors" on the "switch-mode-power-supply/CCFL inverter board. If, as you say "works for 5 or 6 seconds" then that means that fuse is good. Another thing you will need to inspect SMPS board for is "cold" "frosty looking" solder joints where the components (surface mount or through hole) are soldered to the copper circuit traces. May need large magnifying glass or low power inspection microscope to locate them. Resolder any that look bad or loose. Some solder joints have thinner than "hair" thermal fractures that can also cause YOUR TYPE OF SYMPTOM!! PARTS: digikey. mouser. newark. and possibly Radio Shack. If buying filter capacitors, make sure they are rated 105 deg C only!! NOT 85 deg C!!! If caps need to be replaced (swollen, leaky) be sure to tell us the brand name you find installed on your unit! CAPXON, ELITE, JUN-FU are just 3 that you don"t want to find in your unit. BAD news if you do!! If DIY suits you, remember to document with "close-up" digital stills your unit tear-down, so you can reassemble unit without any "extra" parts laying on kitchen table!! Filter capacitors are polarized. You put them in + to +, - to -!!! if you put them in backwards they go BOOOOMMM!!! Hope this helps a little. lmistyrel on aim or 12fixlouie at fixya.
Posted on Jan 30, 2010
Testimonial: "12fixlouie has been most helpful in helping me find a solution to my monitor problem."
SOURCE: Rotation of Samsung SyncMaster 2243BWX
They are referring to the video card in your COMPUTER, not the monitor. There is a supported list of cards at
Posted on Feb 01, 2010
How to fix Syncmaster 2494hs touch menu problem?
Have you tried doing a factory reset on the monitor? If the problem persists, then it could be an electronics fault or a stuck button.
May 11, 2014 | Samsung Computers & Internet
Turn off passenger airbag
no year, no joy, not posting year, makes this impossible
starting a few years, ago , when they didnt have the switch
you could get the dealers help to defeat it.
you could read the FSM. ITS THERE.
or at all com read bag section , search word defeat.
on newer cars this is a FEATURE.
read the operators guide, if lost get one. buy one, may are free
if you just google.
Dec 03, 2013 | Honda Cars & Trucks
I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Mar 20, 2010 | HP Computers & Internet
The brightness menu screen is stuck on!
Please try to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu from your screen. regards
May 27, 2009 | Samsung SyncMaster 720N Monitor
I cant unlock osd of my samsung monitor , sync master 551v
Please try again to turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. regards
May 27, 2009 | Samsung SyncMaster 151 N 15" LCD Monitor
If you put the time forward a couple of years on your PS2 when you come to him he will be dead of old age there will be oscelot can find this sort of thing on all kinds of cheat sites!
Jan 17, 2009 | Konami Metal Gear Solid 3: Subsistence
Samsung SyncMaster 750S
1. check tha VGA cable is properly connected into the computer
2. possibly CRT board dry solder. you can touch up the solder joint
Apr 17, 2008 | Samsung SyncMaster 750S Monitor
Font Appearance
I have had it happen and used auto adjust, also turn off moniter and wait turn back on. Cured it, then I veiwed a video and boom same problem again? Gotta play with it, use buttons on side to bring up and scroll through menu, try differant things
Nov 20, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Samsung SyncMaster 191T
Sounds like the invertor board in the monitor is bad or the LCD screen has had it and needs replacing.
Jun 04, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Computers & Internet Logo
116 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
