Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
Anonymous Posted on Apr 06, 2012
Hot water heater pilot light will not stay lit
The water heater pilot light would light and turn up the heat. when it got to the temp the pilot light and burner would go out. so i replace the thromocupler the first time the pilot light lit good and the burner cam on when it got to the temp. bout out and now the pilot light will not light after u let up on the the button plz help
  • Anonymous Mar 11, 2014
    have replaced fuel filter and cleaned tank and hoses , pump seems to opporate ok starts and ticks over for a while but wont rev have manually opperated tps seems to make no odds , sonny
Anonymous
Level 1:
New Friend:
  • Contributor 48 Answers
  • Posted on Apr 13, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
48
Questions
0
Helped
28694
Points
93
You need a new gas control valve.
5 Related Answers
jvirgil688
  • 6 Answers
  • Posted on Jun 15, 2009
SOURCE: water heater pilot light won't stay lit
Only thing left to change is the gas valve assembly.
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Jan 23, 2010
SOURCE: pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Testimonial: "exactly what I wanted yo know. thank you"
Anonymous
  • 2992 Answers
  • Posted on Apr 08, 2009
SOURCE: pilot light won't stay lit after release of gas valve.tried few t
Most likely it's time to replace the thermocouple, the safety device that makes sure the pilot is lit. New thermocouples are cheap and you can find them at most hardware stores and the big-box places (Home Depot, etc.)
Here is a site with basic information to get you going.
Anonymous
  • 68 Answers
  • Posted on Aug 30, 2009
SOURCE: water heater pilot wont stay lit
try cleaning the top of the pilot light jet if you can get to with small brush then blow it clean with a compressor.
36069
  • 35 Answers
  • Posted on Nov 19, 2009
SOURCE: I have a gas hot water heater and the pilot won't stay lit
Typically, if you have replaced the thermocoupling and are still experiencing problems, it means the master control valve is bad. It also may be a venting problem, which I would not rule out. If you call the manufacturer with model and serial number, they will be able to help you better diagnose your problem.
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Pilot light on hot water heater is out
you need to shut off the the red nob and turn the nob off in front take the cover off remove the heat shield turn the nob on top to pilot use a piece of paper to light put in next to pilot and hold button down for 20 to 50 secs pilot should stay lit turn nob on front then burner should kick on then you should be all good
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
Water not hot even thermostate turned to high. The pilot light is on. Shoulder I be able to visualise the burner actually firing.,or hear it firing. I can see the pilot light clearly. Please help
If you have cold water now, you should hear the unit fire up and run while heating water. Proceedure would be; pilot is lit with thermostat at pilot setting. Once pilot is lit, you turn up to desired temp setting and you should hear the heater running. Depending on lighting, you should be able to see it slightly brighter and may flicker some while heating.
We change the burner for the water heater, it stay li ari=ound 35 minutes, heat the water and after is turning on completely, even the small flame don't stay lit. What we need to do?
you mean it is only staying on for 35 minutes, if this is the case, then readjust or replace thermal coupling, if bad it will not sense the flame or pilot light. it has to be in pilot light flame as to work properly. ( this is for a gas hot water heater). if bad it will shut gas off to heater.
1helpful
2answers
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
3helpful
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
