Question about Hoover SE230 Front Load Washer
No power to motor
Cleaned pump and all pipe work put new brushes in but no power to motor but pump runs thats all
    Genius:
  • 1,122 Answers
Have you checked the door switch?-mike
Posted on Nov 10, 2008
1987 Nissan D21 with a Z24 motor: Continuous stalling at idle, runs when choked using a rag or hand, has new plugs, wires, distributor cap, rotor button, fuel pump, will not idle unless choked, i do n
need to clean the idle jet out in the carb. you need to take the carb float chamber apart and you will see 2 copper jets. unscrew one jet at a time and clean them out. screw back firm not to tight. wile open clean the filter out of the main fuel line if its black replace with new one or leave to soak in some white vinegar and brush with a old tooth brush put new seal on float chamber and put back on engine. see if its fine then it should be.
Jan 19, 2014 | Cars & Trucks
Washer will not spin. Cleaned drain/filter. Worked for 2 days. Now won't spin and checked drain, it is clean. The drain pump works fine. What to check next?
i had the same problem a year ago. nothing seemed to work. we even got a new washer, same problem. we ended up putting the washer on its own circuit. works fine now.
Feb 16, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a beko 1512s washing machine, it goes thru the cycle but then wont do a final empty and spin. Its not the pump and its not the brushes please help :(
Are you refering to the main motor when you say 'Its not the 'pump' and its not the brushes' or have you been able to check the separate drain pump and clean the filter, please?
Because I do not know your answers and just in case with no promises ;-0) ---------->
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 16, 2011 | General Electric Washing Machines
My marine macerator pump stopped working altogether. What checks need to be performed?
first check if the pump get power. I presume your pump is 12V DC. If you have a dc tong tester that is one way.Or disconnect the motor and reconnect directly to a battery. Then a more crude way to test is to take one lead off and touch it together again. If your pump is stuck but the motor is still o.k. you will get a reasonable spark. No spark: your motor brushes are worn out or your motor is toast. You have a spark your pump is stuck with debris. Try to run it reverse(reverse the power leads) and or clean it out. You can see the cutter knifes from the intake end and should be able to turn them with a screw driver. New pumps on ebay: I paid $125
Jul 29, 2010 | Saniflo SaniGrind Macerator Pump Tank
Motor humswhen turned on. Removed pump and rotated motor shaft, put back together and worked but made a loud clicking noise. turned off and tried to turn back on again. Motor just hums as if something...
I was going to mention the coupling, since that is new, then I would suggest motor brushes or new motor. As long as you are getting sufficient power to the motor. about minimum of 12-13.5 volts
Sep 28, 2009 | Washing Machines
My machine ran over some string,made a funny noise and emitted some smoke,the hand suction pipe at the rear works perfectly, the motor runs fine,but the front of the vacuum will not work.thankyou very...
the string bound up the beater bar (brush), keeps the belt stationary, and the motor spindle is just rubbing against the belt and melting it. remove the belt guard, remove the brush, and the belt. clean off the brush bearings (at the ends of the brush) of the string and make sure the ends spin freely from the brush. replace the belt with a new one, and put it all back together.
Aug 17, 2009 | Panasonic Vacuums
Hello, We purchased a FIMCO sprayer last year, used it twice and stored it indoors. Now the motor will not work. My husband tested it with his meter and power is getting to the motor and past the...
Pull the side cover off the pump of there will be small shaft, turn the shaft it will free it up. You need to make sure that the pump is cleaned out after each use, you can get a cleaning material that you want to run through the hole system, relief valve, spray nozzle etc. it will lubicate everything up. If you did not clean it out it will seeze and you will needs to be freed, chemical will freeze the moto.
Apr 27, 2009 | Garden
Will not empty the water out, water pump works-pipes are clean and motor brushes are new. When the dial is constanly turned eventually it empties
That's odd.
When you say the pump works, I assume you mean you can see it turning?
When you say the pipes are clean, I assume you mean the washing machine's pipes.
Motor brushes? Well, if you can see the pump turning, maybe that's irrelevant.
I'm stumped. Are you sure the pump is turning? Is the impeller connected to the drive shaft? Is the pump belt driven?
Lastly, are you sure your sewage system takes enough water?
Sorry I couldn't be more helpful.
Jul 01, 2008 | Bosch Washing Machines
Hoover SE230 Front Load Washer Logo
73 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
