Question about Plumbing
Eljer lavatory faucet will not shut off. Chrome knob is stuck.
I cannot get access to the faucet stem.I have pushed in the retainer, but cannot remove the chrome knob. Have drilled a hole just above the retainer and flooded inside with liquid wrench. Has sat for several weeks with more liquid wrench added. Called plumber thinking they might have a special removal tool. But, no. The plumber left because he could not remove. I am considering making a hack saw cut above the retainer, hoping i can insert a flat tool and pry the inside brass piece from the chrome. Suggestions appreciated.
Tom Gray
  • Anonymous Dec 26, 2008
    Having same problem with eljer chrome shower knob not coming off. Even with pulling on the knob while holding the pin in and having a 2nd person banging a wrench on the back side of the knob, no luck. If I pull any harder I'm afraid of breaking the brass screw inside or pulling the whole unit out of the wall. Please let me know if you've found a solution.
    Jack
  • Chris Ballard
    Chris Ballard May 11, 2010
    Is your model a wide spread (8" center)? What is a description of the retainer you refer to and where is it in relation to the handle?
  • 119 Answers
If you are trying to remove the handle you need a handle removal tool sold at all hardware stores
Posted on Nov 23, 2009
3 Suggested Answers
  • 148 Answers
SOURCE: Eljer slantback lavatory faucet
use baking soda to remove the corrosion mix a little in apaper cup and brush on with toth brush
I do not have a clear picture but can you not put two screw drivers under the lip of the chrome and pry up
One other thought is to tap the top adapter with a hammer to see if it will break loose
Posted on Dec 30, 2008
  • 349 Answers
SOURCE: How do I install the Moen 10790 Lavatory Faucet
This in link below had a detailed instruction on how to install your drain.
http://www.ehow.com/how_2342611_install-sink-pop-up-drain.html
This link below has a parts view of how it goes together. If you will look the waste seat will be the peice that will go in your sink up top and everything esle underneath.
http://www.plumbersurplus.com/pdf/02535.pdf
Posted on Jun 20, 2010
How do I remove the handle on a Moen Brantford doule handle lavatory faucet
there has to be a small setscrew hole on either handle .otherwise they could not be repaired
Feb 11, 2015 | Moen 6610 Brantford Two Handle Lavatory...
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
I have a Moen Villeta lever lavatory faucet, model # 4721 that is hard to shut off properly. Technically, it doesn't leak but will drip unless you consciously press down hard enough. We have 3 other...
take the knob/handle off, shut the water to the faucet of, unscrew stem, examine and compare with the other working faucet stems, it may need a new stem(cartridge) or a faucet washer. Possible the retainer nut is/was loose. hope this helps Tim
May 29, 2011 | Plumbing
Where does the rubber cup with the hole in it and the spring fit?
They go in the bottom of the stem on most two handle faucet's, Remove stem and replace spring and seat onto it.
May 21, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
My wife turned on the hot water facute in the kitchen when she went to turn it off i will not turn off i took off the knob the nut was a little loose tightened it up still leaks is there a way to repair...
Turn the water off at the shut under the sink and open both faucets to drain line. Remove faucet handle and stem and look inside. There's probably something jamming the stem from turning. Remove that and reassemble.
Feb 21, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Handles are completely stuck. I'm thinking due to Calcium build up. Can't move then at all.
remove the chrome covers from the handle and loosen the nut that pushes the seal around the stem to keep it from leaking. Then try turning the handles. if they still don't turn, take the nut all the way out and remove the stem from the faucet. This will allow you to wire brush all of the corrosion off the faucets. Use a good plumbers grease and put it on the stems before replacing them. do not overtighten brass nut.
Nov 29, 2009 | Kohler K-10272-4A-CP Fort½ Widespread...
How to remove retaining nut on two handle faucet so I can remove stem? Thank you. John
sounds like you need a basin wrench that is made for taking off nuts like this one.  you can find one at local hardware store.
Jun 20, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Replace inside stem on hot water Eljer shower faucet
Sounds like you might need a gear puller -- hardware stores would have them -- or auto parts.
Spray with contact cleaner wd-40 first, then install puller, depress ring and crank away at the puller.
Apr 21, 2009 | Home
Dec 19, 2008 | Plumbing
Plumbing Logo
414 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
